HP ProBook 450 G3 Intel Core i3-6100U 4GB 500GB 15.6" Windows 10 Professional 64-bit
Quicklinx: BSWKWS00 Mfr#: P4P38ET#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
in stock
£441.02 ex VAT
£529.22 inc VAT
Powered by the impressive Intel Core i3-6100U processor and with Intel HD Graphics, the HP ProBook range has been designed for long-lasting performance both in and out of the office.
Enjoy speedy 802.11ac wireless technology for instant web browsing wherever there’s an internet connection, while the Bluetooth 4.0 ensures speedy data transfer.
At just over 2kg in weight, the HP ProBook 450 offers the perfect portability for when you’re working on the move. Measuring 37.8cm x 26.43cm x 2.48cm, it’s thin enough to fit easily into your bag.
The Trusted Platform Module security chip increases security when you’re away from your notebook, reducing the risk of unwanted third parties accessing sensitive documents.
Designed for on-the-road wear and tear, the HP 450 is also spill-resistant – a necessary feature on your daily commute.
Supporting up to 16GB RAM and with a 500GB hard drive, you’ll find there’s plenty of space for large files without compromising on everyday performance.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 450.
  • Tested to go the distance
    Stand up to the workload with an ProBook that passed MIL-STD 810G testing.
  • Help secure critical data
    With TPM your critical data has protection with hardware-based encryption keys.
  • Protect against minor spills
    Help protect your ProBook from minor spills with a spill-resistant HP Premium Keyboard.
  • Customized protection
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
HP ProBook 450 G3 Notebook - 15.6" - Core i3 6100U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i3 (6th Gen) 6100U / 2.3 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Keyboard
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
37.8 cm x 26.43 cm x 2.48 cm
2.07 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
High Definition Audio, DTS Studio Sound
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 3165 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
Intel Wireless Display (WiDi), Miracast, Wake-on-LAN (WOL)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.3az, IEEE 802.11w
4-cell Lithium Ion
44 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
2 x USB 3.0 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, CyberLink Power2Go, HP Recovery Disc Creator, Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Caller Dashboard
Security
HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT, low halogen
Localization
2.07 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
