HP Probook 450 Core i5-8250U 8GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: DC5BWS00 Mfr#: 3KY20ET#ABU
  • Core i5
  • IEEE 802.11n
Built for productivity, the HP ProBook 450 delivers the performance and security features essential for today's workforce. The sleek and tough design provides professionals a flexible platform to stay productive in or out of the office.
  • Powerful processing
    Get through your deadline-driven, multitasking day with optional 7th Gen Intel Core i3/i5 or 8th Gen Core i5/i7 Quad Core processors and optional NVIDIA GeForce discrete graphics.
  • Stylish and durable ultraslim design
    The HP ProBook 450 delivers stylish design to every business. An ultraslim chassis in a refined new natural silver finish includes a keyboard deck made of durable premium stamped aluminum.
  • Designed for docking
    Quickly transition to desktop productivity with a single cable that supports docking via USB-C which allows you to connect multiple external displays, a power source, and a gigabit network connection through optional docks.
  • Immersive experience
    Experience vivid audio engagement and an easy conferencing experience with the Skype for Business Certified HP ProBook 450 with HP Audio Boost, HP Noise Cancellation.
HP ProBook 450 G5 - 15.6" - Core i5 8250U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe, HP Value
Optical Drive
No optical drive
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 14.25 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
37.6 cm x 26.41 cm x 2.08 cm
2.1 kg
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), HP Value
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare, 45% sRGB
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, dual array microphone
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
Run Time
Up to 14.25 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , USB 2.0 (powered) , 2 x USB 3.0 , HDMI , LAN , VGA , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
LANDesk Management Suite, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP 3D DriveGuard 6, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, Native Miracast, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Connection Optimizer, HP BIOSphere Gen4
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
Localization
2.1 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
