Built for productivity, the HP ProBook 450 delivers the performance and security features essential for today's workforce. The sleek and tough design provides professionals a flexible platform to stay productive in or out of the office.
Let nothing stand in your way
Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 450. -
Protect your data with multi-factor authentication
Fortify your security by using multiple factors of authentication including fingerprints and facial recognition. -
Storage options
Get the best of both worlds with dual solid-state and hard drive storage options from HP. -
Outstanding battery life and fast charging
Battery life that gets you through the workday and beyond. Fast charge 90% in 90 minutes. -
Stay Connected
Stay connected with self-healing wireless driver technology and support for the latest global 4G LTE wireless broadband technology. -
Tested to go the distance
Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
- HP ProBook 450 G5 Notebook - 15.6" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel UHD Graphics 620
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 14.25 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 37.6 cm x 26.41 cm x 2.08 cm
- 2.1 kg
- Localisation
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz / PC4-19200
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Colour Gamut
- 45% sRGB
- HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Sound
- Stereo speakers, dual array microphone
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSH
- Dual stream (2x2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 14.25 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 2.0 (powered) , 2 x USB 3.0 , HDMI , LAN , VGA , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- LANDesk Management Suite, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP 3D DriveGuard 6, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, Native Miracast, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Connection Optimizer, HP BIOSphere Gen4
- Security
- BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
- Localization
- 2.1 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
