The thin, light, tough design of the HP ProBook 440 gives mobile professionals powerful tools to stay productive on the go. Equipped for productivity, this ProBook delivers the performance and security features essential for today's mobile workforce.
Designed for mobility
Travel in style with the thin and light 35.56 cm (14-inch) diagonal HP ProBook 440 with a new asteroid silver design. Confidently take on the day with a PC that’s designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard deck.
Powerful processing
Power through projects with 7th Gen Intel® Core™ i3/i5/i7 processors and optional NVIDIA® GeForce® discrete graphics.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere as well as the embedded TPM and an optional fingerprint reader.
Immersive experience
Enjoy the rich user experience of the HP ProBook 440 with long battery life and features designed to create a stunning visual and audio experience with HP Audio Boost, HP Noise Cancellation, and options like an FHD display, and an HD touch display.
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 440. -
Tested to go the distance
Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing. -
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Cancellation Software. -
Give your speakers a boost
Help make good speakers sound great with the HP Audio Boost. -
Help secure critical data
With TPM 2.0 embedded security your critical data has protection with hardware-based encryption keys. -
Protect against minor spills
Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
- HP ProBook 440 G4 Notebook - 14" - Intel Core i5 - 7200U - 4 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 256 GB SSD
- Display
- 14" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Gigabit Ethernet
- Battery
- 3-cell - up to 15.5 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 34.32 cm x 23.9 cm x 2.03 cm
- 1.64 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD standard-viewing angle (SVA) anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- Conexant CX7700
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, built-in numeric keypad
Communications
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 15.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 2.0 (power only) , USB 3.0 , USB-C , HDMI , Headphone/microphone combo jack , LAN , VGA
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard
- Security
- HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, Preboot Security, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
- Localization
- 1.64 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
