HP ProBook 440 G4 Intel Core i3-7100U 4GB 500GB W10P
Quicklinx: CP8KWS00 Mfr#: Y7Z80EA#ABU
Display Size: 14in
Processor Model: I3-7100U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i3
  • IEEE 802.11n
£506.66 ex VAT
£607.99 inc VAT
The thin, light, tough design of the HP ProBook 440 gives mobile professionals powerful tools to stay productive on the go. Equipped for productivity, this ProBook delivers the performance and security features essential for today's mobile workforce.
Designed for mobility
Travel in style with the thin and light 35.56 cm (14-inch) diagonal HP ProBook 440 with a new asteroid silver design. Confidently take on the day with a PC that’s designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard deck.
Powerful processing
Power through projects with 7th Gen Intel® Core™ i3/i5/i7 processors and optional NVIDIA® GeForce® discrete graphics.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere as well as the embedded TPM and an optional fingerprint reader.
Immersive experience
Enjoy the rich user experience of the HP ProBook 440 with long battery life and features designed to create a stunning visual and audio experience with HP Audio Boost, HP Noise Cancellation, and options like an FHD display, and an HD touch display.
  • Designed for mobility
    Travel in style with the thin and light 35.56 cm (14-inch) diagonal HP ProBook 440 with a new asteroid silver design. Confidently take on the day with a PC that's designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard deck.
  • Powerful processing
    Power through projects with 7th Gen Intel Core i3/i5/i7 processors and optional NVIDIA GeForce discrete graphics.
  • Safeguard data and devices
  • Immersive experience
HP ProBook 440 G4 - 14" - Core i3 7100U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (7th Gen) 7100U / 2.4 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
34.32 cm x 23.9 cm x 2.03 cm
1.64 kg
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Slim Design, HD standard-viewing angle (SVA) anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Codec
Conexant CX7700
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB 2.0 (power only) , USB 3.0 , USB-C , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard
Security
HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, Preboot Security, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
1.64 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ProBook 440 G4 Intel Core i3-7100U 4GB 500GB W10P Bundle deal on HP ProBook 440 G4 Intel Core i3-7100U 4GB 500GB W10P
£688.82
saving £8.33
£605.83
Display Size: 14in
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: HDD
Type: Laptop
Brand: HP
Price Range Ex VAT: 500 - 750
