HP ProBook 400 G4 Intel Core i5-7200U 4GB 500GB W10P
Quicklinx: CP4WWS00 Mfr#: Y7Z73EA#ABU
  • Core i5
  • IEEE 802.11n
The thin, light, tough design of the HP ProBook 440 gives mobile professionals powerful tools to stay productive on the go. Equipped for productivity, this ProBook delivers the performance and security features essential for today's mobile workforce.
Designed for mobility
Travel in style with the thin and light 35.56 cm (14-inch) diagonal HP ProBook 440 with a new asteroid silver design. Confidently take on the day with a PC that's designed to pass MIL-STD 810G testing, built with an aluminum reinforced keyboard deck.
Powerful processing
Power through projects with 7th Gen Intel Core i3/i5/i7 processors and optional NVIDIA GeForce discrete graphics.
Safeguard data and devices
Help keep sensitive data secure with comprehensive security features like HP BIOSphere as well as the embedded TPM and an optional fingerprint reader.
Immersive experience
Enjoy the rich user experience of the HP ProBook 440 with long battery life and features designed to create a stunning visual and audio experience with HP Audio Boost, HP Noise Cancellation, and options like an FHD display, and an HD touch display.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 440.
  • Tested to go the distance
    Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
  • Cut out the chatter
    Help suppress ambient noise including keyboard clicks with HP Noise Cancellation Software.
  • Give your speakers a boost
    Help make good speakers sound great with the HP Audio Boost.
  • Help secure critical data
    With TPM 2.0 embedded security your critical data has protection with hardware-based encryption keys.
  • Protect against minor spills
    Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
HP ProBook 440 G4 Notebook - 14" - Intel Core i5 - 7200U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 15.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
34.32 cm x 23.9 cm x 2.03 cm
1.64 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Slim Design, HD standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Video Resolutions
1280 x 720
Camera Features
720p HD movie recording
Sound
Stereo speakers, two microphones
Codec
Conexant CX7700
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
48 Wh
Run Time
Up to 15.5 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB 3.0 , USB 2.0 (power only) , USB-C , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, Preboot Security, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
1.64 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
