HP Pro x2 612 G2 Intel Core i5-7Y54 4GB 256GB SSD 12" Touchscreen Windows 10 Professional 64-bit
Quicklinx: F6ZTWS00 Mfr#: L5H57EA#ABU
Display Size: 12in
Processor Model: I5-7Y54
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,036.91 ex VAT
£1,244.29 inc VAT
The versatile HP Pro x2 design strikes the right balance of mobility, durability, and security in a device that is designed to last. Ideal for challenging environments, this versatile detachable PC lets you work the way you want.
  • Strong security, simplified manageability
    Take security to the next level with a built-in smart card reader and optional fingerprint reader. Protect against BIOS attacks with HP Sure Start Gen3 and easily manage devices with the HP Manageability Integration Kit.
  • Adapts to the way you work
    Explore your creative potential with the extended 165° kickstand opening and the optional HP Active Pen with App Launch for a natural inking experience. Use in tablet mode for surfing, or attach the optional HP Pro x2 Collaboration Keyboard and use it as a notebook.
  • Field ready
    This detachable can go the distance passing MIL-STD 810G tests for dust, shock, drops, and more. The HP Pro x2 is up to the task with up to 11 hours of battery life, and a fanless design for quiet operation.
  • Delighting users, helping IT
    The HP Pro x2 removable back cover allows fast easy upgrades to serviceable components in the field saving time and money and helping extend the life of your investment.
HP Pro x2 612 G2 - 12" - Core i5 7Y54 - 4 GB RAM - 256 GB SSD
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7Y54 / 1.2 GHz (3.2 GHz) / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD SED, TCG Opal Encryption 2, TLC
Display
12" LED backlight touchscreen 1920 x 1280 / WUXGA+ - 192 ppi
Graphics
Intel HD Graphics 615
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10 hours
Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Dimensions (WxDxH) - tablet
30 cm x 21.93 cm x 0.91 cm
850 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (provided memory is soldered)
Max RAM Supported
8 GB
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) SATA 6Gb/s - Self-Encrypting Drive, TCG Opal Encryption 2, triple-level cell (TLC)
Display
12"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
Widescreen
Pixel Density (ppi)
192
Image Brightness
340 cd/m²
Ultra Slim Design, Corning Gorilla glass 4, WUXGA+ ultra wide-viewing angle (UWVA) BrightView eDP +PSR
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1080p
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Frame Rate
30 frames per second
Sound
Stereo speakers, two microphones
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
41.58 Wh
Run Time
Up to 10 hours
AC Adapter
Output
65 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
Slots
1 x Micro-SIM card (1 free)
USB-C 3.1 (docking and charging) , USB 3.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Integrated Options
Dockable
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Keyboard
Localization
850 g
Dimensions (WxDxH) / Weight Details
30 cm x 21.93 cm x 0.91 cm / 850 g - tablet
ENERGY STAR Certified
Software applications
HP Pro x2 612 G2 Intel Core i5-7Y54 4GB 256GB SSD 12 Bundle deal on HP Pro x2 612 G2 Intel Core i5-7Y54 4GB 256GB SSD 12" Touchscreen Windows 10 Professional 64-bit
£1,136.08
Display Size: 12in
Optical Storage: None
Graphics: Intel HD Graphics 615
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 1000 - 1500
