HP Pro x2 612 G1 Intel Core i5-4302Y 4GB 180GB SSD 12.5" Touchscreen Windows 7 Professional 64-bit
Quicklinx: BKRWWS00 Mfr#: J9Z38AW#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Mobility without compromise. Maximize productivity with the convenience of a tablet and the power of a notebook. Work confidently in or out of the office with commercial grade security and connectivity.
  • Designed for business
    Optimized for productivity, the HP Pro x2 612 tablet packs in all the features you rely on including a large display with the built in connectivity, security, and high performance you need for everyday business.
  • High performance tablet
    Replace your traditional notebook with a tablet that lets you perform at your best with the choice of 4th Gen Intel Core processors, fast SSDs, and longer battery life when paired with the optional power keyboard.
  • Security for business
    Replace your traditional notebook with the HP Pro x2 612 G1. 2-in-1 solutions let you perform at your best with optional 4th generation Intel Core i3/i5 processors, fast solid state drives, and longer battery life when paired with the optional HP Pro x2 612 G1 Power Keyboard.
  • Tablet or 2 in 1, you choose
    Purchase your complete business mobility solution today. Choose the optional power keyboard with the optional HP UltraSlim Docking Station, or the travel keyboard for a lighter option.
  • Featuring
    Enjoy smooth and precise interaction with select models using the optional HP Pro x2 612 Wacom Pen with high performance pressure sensitivity and smart palm rejection technology.Functions as a full notebook by utilizing two USB 3.0 ports, DisplayPort, VGA and RJ45 on the HP Pro x2 612 G1 Power Keyboard. The Power Keyboard also supports enterprise docking with a side connector for the optional HP UltraSlim Docking Station.The HP Pro x2 612 Travel Keyboard helps you travel light and stay productive on the go.Easily collaborate with colleagues using the 12.5-inch diagonal FHD tablet with an optional Wacom Pen, Qualcomm Gobi 4G LTE, dual HD webcams, and HP Noise Reduction Software.Get to work virtually anywhere in the world with fast, reliable, and secure wireless connections using optional Qualcomm Gobi 4G LTE connectivity.
HP Pro x2 612 G1 - 12.5" - Intel Core i5 - 4302Y - vPro - 4 GB RAM - 180 GB SSD - UK
Tablet - with keyboard dock
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Platform Technology
Intel vPro Platform
Intel Core i5 (4th Gen) - 4302Y / 1.6 GHz, up to 2.3 GHz / 3 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
180 GB SSD
Display
12.5" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 4200
Input Device
Keyboard, digitizer, touchpad, Tablet Pen
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) - tablet
30.7 cm x 20.95 cm x 1.28 cm
958.7 g
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4302Y / 1.6 GHz
Max Turbo Speed
2.3 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
180 GB SSD M.2 SATA 6Gb/s
Display
12.5" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Ultra Slim Design, Corning Gorilla glass 3, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Camera Features
1080p Full HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3228
High Definition Audio, DTS SOUND+
Input
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Lithium polymer
Installed Qty
2
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB 3.0 , Headphone/microphone combo jack , 2 x USB 3.0 (on keyboard dock) , DisplayPort (on keyboard dock) , VGA (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock (on keyboard dock) , LAN (on keyboard dock)
Memory Card Reader
Yes (SD Card, SDHC Card, microSD, SDXC Card, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Spare Key, Microsoft Internet Explorer 10, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability
Integrated Options
Dockable
Security
Microphone with echo and noise-cancellation, HP SureStart, Full Volume Encryption, 1 USB 3.0 charging port
Power adapter
RoHS, WEEE
Localization
958.7 g
Dimensions (WxDxH) / Weight Details
31.7 cm x 23.95 cm x 2.33 cm - tablet with keyboard
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
