HP Pro Tablet 608 G1 Intel Atom x5 Z8500 4GB 64GB 7.9" Windows 10 Professional 64-bit
Quicklinx: BPKDWS00 Mfr#: H9X44EA#ABU
  • IEEE 802.11n
  • Bluetooth 4.0
Transform your business with this small stylish business tablet equipped with a brilliant, high definition display and the pervasive connectivity to mobilize most any business process. Choose from an expansive choice of accessories for a customized experience.
  • Easily secured
    Get business-class security and manageability options on the HP Pro Tablet 608 with multi-factor authentication, Enterprise Data Protection, HP Client Security, HP Touchpoint Manager, and more.
  • Brilliant performance in a small package
    Small, thin, and light tablet performance gets a boost with an impressively powerful QXGA display, the Cortana virtual personal assistant, plus a powerful combination of connectivity and performance to support your business needs.
  • Create efficiencies with mobile solutions
    Tailor your experience to the needs of your business with a keyboard, cases, portable docking station and more to customize your tablet.
  • Your trusted migration partner
    From readiness workshops to free help with migration, HP and our partners will get your company up and running on Windows 10. HP helps you prepare your environment, and implement the right solution with the right hardware.
HP Pro Tablet 608 G1 - 7.86" - Intel Atom x5 - Z8500 - 4 GB RAM - 64 GB eMMC - 4G LTE
Tablet - no keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Atom x5 Z8500 / 1.44 GHz, up to 2.24 GHz / 2 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
64 GB eMMC
Display
7.86" WLED touchscreen 2048 x 1536 / QXGA
Graphics
Intel HD Graphics
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
Wireless Broadband (WWAN)
4G LTE
Service Provider
Service not included
2-cell - up to 8 hours
Ambient light sensor, proximity sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip
Grey
20.7 cm x 13.7 cm x 0.835 cm
420 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
2.24 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
64 GB eMMC
Display
7.86"
LCD Backlight Technology
WLED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2048 x 1536 (QXGA)
Widescreen
No
Image Aspect Ratio
4:3
Image Brightness
450 cd/m²
BrightView, ultra wide viewing angle, Direct Bonding technology, anti-smudge, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - HD
Resolution
8 Megapixel (rear), 2 Megapixel (front)
Sound
Stereo speakers, two microphones
High Definition Audio, DTS Studio Sound
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Intel Wireless Display (WiDi), Miracast
Generation
4G
HSPA+, LTE
Controller
HP lt4112
Service Provider
Navigation
Receiver
GPS
2-cell lithium polymer
21 Wh
Run Time
Up to 8 hours
Battery Run Time
Video playback: up to 8 hours
AC Adapter
Input
Output
15 Watt
Connections & Expansion
USB-C , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD, microSDXC)
Software
Software Included
Skype, Adobe Shockwave Player, HP ePrint, HP Connected Photo, HP PageLift, HP Wireless Hotspot, HP Touchpoint Manager
Grey
Integrated Options
Dockable
Security
Digital compass, Accelerometer, capacitive touch screen, gyroscope, Haptics
Power adapter
CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FCC CFR47 Part 15, EN 60950-1, EN 301 908, EN 62311, EN 300.440, EN 300 328, EN 301 489, FCC CFR47 Part 2, EN 301 893
Localization
420 g
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
