Transform your business with this small stylish business tablet equipped with a brilliant, high definition display and the pervasive connectivity to mobilize most any business process. Choose from an expansive choice of accessories for a customized experience.
Easily secured
Get business-class security and manageability options on the HP Pro Tablet 608 with multi-factor authentication, Enterprise Data Protection, HP Client Security, HP Touchpoint Manager, and more. -
Brilliant performance in a small package
Small, thin, and light tablet performance gets a boost with an impressively powerful QXGA display, the Cortana virtual personal assistant, plus a powerful combination of connectivity and performance to support your business needs. -
Create efficiencies with mobile solutions
Tailor your experience to the needs of your business with a keyboard, cases, portable docking station and more to customize your tablet. -
Your trusted migration partner
From readiness workshops to free help with migration, HP and our partners will get your company up and running on Windows 10. HP helps you prepare your environment, and implement the right solution with the right hardware.
- HP Pro Tablet 608 G1 - 7.86" - Intel Atom x5 - Z8500 - 4 GB RAM - 64 GB eMMC - 4G LTE
- Product Type
- Tablet - no keyboard
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Atom x5 Z8500 / 1.44 GHz, up to 2.24 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 7.86" WLED touchscreen 2048 x 1536 / QXGA
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- Service not included
- Battery
- 2-cell - up to 8 hours
- Ambient light sensor, proximity sensor, hall sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Grey
- 20.7 cm x 13.7 cm x 0.835 cm
- 420 g
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.24 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 64 GB eMMC
Display
- 7.86"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2048 x 1536 (QXGA)
- Widescreen
- No
- Image Aspect Ratio
- 4:3
- Image Brightness
- 450 cd/m²
- BrightView, ultra wide viewing angle, Direct Bonding technology, anti-smudge, Corning Gorilla glass 4
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - HD
- Resolution
- 8 Megapixel (rear), 2 Megapixel (front)
- Sound
- Stereo speakers, two microphones
- High Definition Audio, DTS Studio Sound
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Intel Wireless Display (WiDi), Miracast
- Generation
- 4G
- Technology
- HSPA+, LTE
- Controller
- HP lt4112
- Service Provider
Navigation
- Receiver
- GPS
- Technology
- 2-cell lithium polymer
- Capacity
- 21 Wh
- Run Time
- Up to 8 hours
- Battery Run Time
- Video playback: up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 15 Watt
Connections & Expansion
- USB-C , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSD, microSDXC)
Software
- Software Included
- Skype, Adobe Shockwave Player, HP ePrint, HP Connected Photo, HP PageLift, HP Wireless Hotspot, HP Touchpoint Manager
- Grey
- Integrated Options
- Dockable
- Security
- Digital compass, Accelerometer, capacitive touch screen, gyroscope, Haptics
- Included Accessories
- Power adapter
- CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FCC CFR47 Part 15, EN 60950-1, EN 301 908, EN 62311, EN 300.440, EN 300 328, EN 301 489, FCC CFR47 Part 2, EN 301 893
- Localization
- 420 g
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 240 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 1.043 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 3.5 g @ RMS (random)
