HP Pro Slate 8 Rugged Case
Quicklinx: BNSWWS00 Mfr#: K3P97AA
Help shield your tablet from bumps wherever you work with the stylish and durable business rugged HP Pro 8 Rugged Case.
  • Designed for function
    Simply insert the tablet into the case, its pen into the holder, and keep all of your tablet's buttons, controls, cameras, and connectors easily accessible.
  • Easy to use
    Use the handy lanyard to carry between meetings.
  • World-class support
    Rest easy with a one-year parts replacement limited warranty.
HP - protective case for tablet
Protective case for tablet
19.2 cm x 2.07 cm x 27 cm
265 g
Pro Slate 8
19.2 cm
2.07 cm
27 cm
265 g
Carrying Case
Protective case
Recommended Use
For tablet
Carrying Strap
Lanyard
Rugged, port cut-outs, adjustable lanyard
HP Pro Slate 8
