Help shield your tablet from bumps wherever you work with the stylish and durable business rugged HP Pro 8 Rugged Case.
Designed for function
Simply insert the tablet into the case, its pen into the holder, and keep all of your tablet's buttons, controls, cameras, and connectors easily accessible. -
Easy to use
Use the handy lanyard to carry between meetings. -
World-class support
Rest easy with a one-year parts replacement limited warranty.
- HP - protective case for tablet
- Product Type
- Protective case for tablet
- 19.2 cm x 2.07 cm x 27 cm
- 265 g
- Designed For
- Pro Slate 8
- 19.2 cm
- 2.07 cm
- 27 cm
- 265 g
Carrying Case
- Protective case
- Recommended Use
- For tablet
- Carrying Strap
- Lanyard
- Rugged, port cut-outs, adjustable lanyard
- Designed For
- HP Pro Slate 8
