Your basket is empty
HP Pro Slate 8 APQ8074 2GB 32GB 7.8" Android 5.0 (Lollipop)
Quicklinx: BHT8WS00 Mfr#: K7X62AA#ABU
  • Android 4.4.4 (KitKat)
Work seamlessly with the HP Pro Slate 8, a full HD tablet which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an HP Duet Pen.
HP Pro Slate 8 - tablet - Android 4.4.4 (KitKat) - 32 GB - 7.86"
Tablet
Operating System
Android 4.4.4 (KitKat) - English
Display
7.86" IPS TFT - 2048 x 1536 (326 ppi) - Multi-Touch
QUALCOMM Snapdragon 800 (Quad-Core)
Processor Clock Speed
2.3 GHz
Storage
32 GB eMMC
RAM
2 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
802.11a/b/g/n/ac, NFC, Bluetooth 4.0 LE
Camera
8 Megapixel (rear), 2 Megapixel (front)
HD Video Recording
1080p
Navigation System
GPS
Battery Run Time
Up to 13.75 hours
13.699 cm x 7.99 cm x 20.699 cm
350 g
Grey
English / United Kingdom
1 year warranty
Tablet
Operating System
Display
7.86" IPS TFT
Resolution
Touchscreen
Multi-Touch
Image Aspect Ratio
4:3
10-point multi-touch, Direct Bonding technology, Corning Gorilla glass 4, Wide Viewing Angle
2.3 GHz
Number of Cores
Quad-Core
Storage
32 GB eMMC
RAM
2 GB - LPDDR3 SDRAM
microSD
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
Wi-Fi Miracast
Camera
Resolution (MP)
Focus Adjustment
Automatic
HD Video Recording
1080p
HDR (High Dynamic Range)
Navigation System
Receiver
GPS
Multimedia
Audio
Two microphones, stereo speakers
Software
Preloaded Software
Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, avast! Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software
Expansion and Connectivity
Expansion Slots
1 x Nano-SIM card , 1 x microSD
1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter)
Installed Qty (Max Supported)
1
Lithium polymer
21 Wh
Run Time
Up to 13.75 hours
Run Time Details
Video playback: up to 13.75 hours
Grey
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
Capacitive touch screen, soft-touch surface, SecureBoot, smudge-resistant, ARM TrustZone, DTS Sound+
Power adapter, stylus
Micro-USB to USB cable - 1 m
CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 301.893, EN 62311, EN 300.440, EN 300 328, EN 301 489, FCC CFR47 Part 2
13.699 cm
7.99 cm
20.699 cm
350 g
Limited warranty - 1 year , Limited warranty - battery - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
