Work seamlessly with the HP Pro Slate 8, a full HD tablet which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an HP Duet Pen.
Designed to defend
Help protect your tablet with device authentication and tamper-resistant features. -
Enterprise-friendly
Customize your enterprise mobility solution with HP Managed Mobility Services. -
Cloud-based IT management made simple
Manage data, security, and a wide array of branded devices from the cloud with HP Touchpoint Manager. Use Locate Device to remotely locate, lock, and wipe your tablet. -
Ready for your environment
Easily integrate your devices with optional, leading EMM solutions. -
Speed, mobility, and style
Get quick app responsiveness and pristine graphics from a Qualcomm processor. -
Easy on the eyes
Enjoy stunning full HD ultra-high 2048 x 1536 resolution on a 20 cm (7.9") diagonal Corning Gorilla Glass screen.
- HP Pro Slate 8 - tablet - Android 4.4.4 (KitKat) - 32 GB - 7.86"
- Product Type
- Tablet
- Operating System
- Android 4.4.4 (KitKat) - English
- Display
- 7.86" IPS TFT - 2048 x 1536 (326 ppi) - Multi-Touch
- Processor
- Qualcomm Snapdragon 800 (Quad-Core)
- Processor Clock Speed
- 2.3 GHz
- Storage
- 32 GB eMMC
- RAM
- 2 GB
- Supported Flash Memory Cards
- microSD
- Wireless Connectivity
- Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 2 Megapixel
- Navigation System
- GPS
- Battery Run Time
- Up to 13.75 hours
- 13.699 cm x 7.99 cm x 20.699 cm
- 350 g
- Grey
- Localisation
- English / United Kingdom
- 1-year warranty
- Product Type
- Tablet
- Operating System
Display
- 7.86" IPS TFT
- Resolution
- Touchscreen
- Multi-Touch
- Image Aspect Ratio
- 4:3
- 10-point multi-touch, Direct Bonding technology, Corning Gorilla glass 4, Wide Viewing Angle
- Processor
- 2.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 32 GB eMMC
- RAM
- 2 GB - LPDDR3 SDRAM
- microSD
- Max Supported Capacity
- 32 GB
Communications
- Wi-Fi Miracast
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- HDR Mode
- Auto HDR mode
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS
Multimedia
- Audio
- Two microphones, stereo speakers
Software
- Preloaded Software
- Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, Avast Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software
Expansion and Connectivity
- Expansion Slots
- 1 x Nano-SIM card , 1 x microSD
- 1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter)
- Installed Qty (Max Supported)
- 1
- Technology
- Lithium polymer
- Capacity
- 21 Wh
- Run Time
- Up to 13.75 hours
- Run Time Details
- Video playback: up to 13.75 hours
- Grey
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
- Capacitive touch screen, soft-touch surface, SecureBoot, smudge-resistant, ARM TrustZone, DTS Sound+
- Included Accessories
- Power adapter, stylus
- Cables Included
- Micro-USB to USB cable - 1 m
- CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 62311, EN 300.440, EN 300 328, EN 301 489, FCC CFR47 Part 2, EN 301 893
- Localisation
- 13.699 cm
- 7.99 cm
- 20.699 cm
- 350 g
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
