Your basket is empty
HP Pro Slate 12 Qualcomm Snapdragon APQ8074-AB 2GB 32GB 4G LTE 12.3" Android 4.4.4 (KitKat)
Quicklinx: BBF0WS00 Mfr#: K7X88AA#ABU
  • Android 4.4.4 (KitKat)
Work seamlessly with the HP Pro Slate 12, which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an integrated HP Duet Pen.
HP Pro Slate 12 - tablet - Android 4.4.4 (KitKat) - 32 GB - 12.3" - 4G - service not included
Tablet
Operating System
Android 4.4.4 (KitKat) - English
Carrier
Service not included
Display
12.3" IPS - 1600 x 1200 (163 ppi) - Multi-Touch
QUALCOMM Snapdragon 800 (Quad-Core)
Processor Clock Speed
2.3 GHz
Storage
32 GB eMMC
RAM
2 GB
Supported Flash Memory Cards
microSD
Cellular Technology
4G
Cellular Protocols
HSPA+, LTE
Wireless Connectivity
802.11a/b/g/n/ac, NFC, Bluetooth 4.0 LE
Camera
8 Megapixel (rear), 2 Megapixel (front)
HD Video Recording
1080p
Navigation System
GPS
Battery Run Time
Up to 14.75 hours
22.195 cm x 0.799 cm x 30.03 cm
850 g
Grey
English / United Kingdom
1 year warranty
Tablet
Operating System
Carrier
Display
12.3" IPS
Resolution
Touchscreen
Multi-Touch
Image Aspect Ratio
4:3
10-point multi-touch, Direct Bonding technology, Corning Concore Glass, Wide Viewing Angle
2.3 GHz
Number of Cores
Quad-Core
Storage
32 GB eMMC
RAM
2 GB - LPDDR3 SDRAM
microSD
Max Supported Capacity
32 GB
Communications
Cellular Technology
4G
Cellular Protocols
HSPA+, LTE
Security Protocols & Features
Wi-Fi Miracast, Android Beam
Camera
Resolution (MP)
Focus Adjustment
Automatic
HD Video Recording
1080p
HDR (High Dynamic Range)
Navigation System
Receiver
GPS
Multimedia
Audio
Two microphones, stereo speakers
Software
Preloaded Software
Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, avast! Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software
Expansion and Connectivity
Expansion Slots
1 x microSD , 1 x Nano-SIM card , 1 x ZIF
1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter)
Lithium polymer
37 Wh
Run Time
Up to 14.75 hours
Run Time Details
Video playback: up to 14.75 hour(s)
Grey
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
Capacitive touch screen, UV protection, soft-touch surface, Data-at-Rest Encryption, SecureBoot, smudge-resistant, ARM TrustZone, DTS Sound+, TrustZone-based Key Store, 256-bit hardware acceleration
Power adapter, stylus, SD/SIM card tray eject tool
Micro-USB to USB cable
CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 301.893, EN 301.908, EN 62311, EN 300.440, EN 300 328, EN 301 489
22.195 cm
0.799 cm
30.03 cm
850 g
Limited warranty - 1 year , Limited warranty - battery - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
