Work seamlessly with the HP Pro Slate 12, which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an integrated HP Duet Pen.
Designed to defend
Help protect your tablet with device authentication and tamper-resistant features. -
Enterprise-friendly
Customize your enterprise mobility solution with HP Managed Mobility Services. -
Cloud-based IT management made simple
Manage data, security, and a wide array of branded devices from the cloud with HP Touchpoint Manager. Use Locate Device to remotely locate, lock, and wipe your tablet. -
Ready for your environment
Easily integrate your devices with optional, leading EMM solutions. -
Excel with built-in extras
Do more with up to 32 GB storage, micro USB 2.0 connectivity, and integrated communication tools. -
Functional for business
Go business-class all the way with innovative optional accessories that connect easily with a zero-force, Pogo pin connector. Make it yours with a choice of adapters, HP Bluetooth Keyboard Folio or HP Paper Folio for use with the HP Duet Pen.
- HP Pro Slate 12 - tablet - Android 4.4.4 (KitKat) - 32 GB - 12.3" - 4G - service not included
- Product Type
- Tablet
- Operating System
- Android 4.4.4 (KitKat) - English
- Carrier
- Service not included
- Display
- 12.3" IPS - 1600 x 1200 (163 ppi) - Multi-Touch
- Processor
- Qualcomm Snapdragon 800 (Quad-Core)
- Processor Clock Speed
- 2.3 GHz
- Storage
- 32 GB eMMC
- RAM
- 2 GB
- Supported Flash Memory Cards
- microSD
- Cellular Technology
- 4G
- Cellular Protocols
- HSPA+, LTE
- Wireless Connectivity
- Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 2 Megapixel
- Navigation System
- GPS
- Battery Run Time
- Up to 14.75 hours
- 22.195 cm x 0.799 cm x 30.03 cm
- 850 g
- Grey
- Localisation
- English / United Kingdom
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Carrier
Display
- 12.3" IPS
- Resolution
- Touchscreen
- Multi-Touch
- Image Aspect Ratio
- 4:3
- 10-point multi-touch, Direct Bonding technology, Corning Concore Glass, Wide Viewing Angle
- Processor
- 2.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 32 GB eMMC
- RAM
- 2 GB - LPDDR3 SDRAM
- microSD
- Max Supported Capacity
- 32 GB
Communications
- 4G
- HSPA+, LTE
- Wi-Fi Miracast, Android Beam
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- HDR Mode
- Auto HDR mode
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS
Multimedia
- Audio
- Two microphones, stereo speakers
Software
- Preloaded Software
- Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, Avast Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software
Expansion and Connectivity
- Expansion Slots
- 1 x microSD , 1 x Nano-SIM card , 1 x ZIF
- 1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter)
- Technology
- Lithium polymer
- Capacity
- 37 Wh
- Run Time
- Up to 14.75 hours
- Run Time Details
- Video playback: up to 14.75 hour(s)
- Grey
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor
- Capacitive touch screen, UV protection, soft-touch surface, Data-at-Rest Encryption, SecureBoot, smudge-resistant, ARM TrustZone, DTS Sound+, TrustZone-based Key Store, 256-bit hardware acceleration
- Included Accessories
- Power adapter, stylus, SD/SIM card tray eject tool
- Cables Included
- Micro-USB to USB cable
- CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 301 908, EN 62311, EN 300.440, EN 300 328, EN 301 489, EN 301 893
- Localisation
- 22.195 cm
- 0.799 cm
- 30.03 cm
- 850 g
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
