Expand your tablet workspace and your productivity with the HP Pro Portable Tablet Dock, an easy-to-use dock designed for the HP Pro Tablet series.
Expansive connectivity
Customize a professional desktop solution by connecting your tablet to an external display, wired network, and your everyday devices with HDMI, RJ-45, USB, and audio ports. -
Easy portability
Take your dock and go. The compact size fits easily in a carrying case alongside your tablet. -
Charge up
Set the tablet in the dock to charge its battery while you work. The recessed tablet holder slot has a 105-degree viewing angle so you can comfortably interact with the screen.
- HP Pro Portable Dock - docking station - HDMI - 10Mb LAN
- Product Type
- Docking station
- Video Interfaces
- HDMI
- 11 cm x 10 cm x 1.9 cm
- 233 g
- Black
- Networking
- Ethernet
- Power
- Power adapter
- 1-year warranty
- Designed For
- Pro Slate 12, 8; Pro Tablet 608 G1
- Product Type
- Docking station
- 11 cm
- 10 cm
- 1.9 cm
- 233 g
- Enclosure Colour
- Black
- Data Link Protocol
- Ethernet
- 1 x USB 2.0 - 4 pin USB Type A , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x network - Ethernet - RJ-45
- Stainless steel magnetic connector
- Power Device
- Power adapter
- Limited warranty - 1 year
- 0 °C
- 35 °C
- Designed For
- HP Pro Slate 12, 8 , HP Pro Tablet 608 G1
