HP Pro Book 450 G5 Intel Core i3-7100U 8GB 256GB SSD Windows 10 Pro
Quicklinx: D6H7WS00 Mfr#: 2UB82ET#ABU
  • Core i3
  • IEEE 802.11n
  • Let nothing stand in your way
    Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 450.
  • Protect your data with multi-factor authentication
    Fortify your security by using multiple factors of authentication including fingerprints and facial recognition.
  • Storage options
    Get the best of both worlds with dual solid-state and hard drive storage options from HP.
  • Outstanding battery life and fast charging
    Battery life that gets you through the workday and beyond. Fast charge 90% in 90 minutes.
  • Stay Connected
    Stay connected with self-healing wireless driver technology and support for the latest global 4G LTE wireless broadband technology.
  • Tested to go the distance
    Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
HP ProBook 450 G5 Notebook - 15.6" - Intel Core i3 - 7100 - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro - English
Intel Core i3 (7th Gen) - 7100 / 3.9 GHz / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, TLC, HP Value
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 630
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
37.6 cm x 26.3 cm x 2.09 cm
2.02 kg
Notebook
Operating System
Windows 10 Pro - English
Processor / Chipset
CPU
Intel Core i3 (7th Gen) 7100 / 3.9 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC), HP Value
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Colour Gamut
45% sRGB
HD standard-viewing angle (SVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, dual array microphone
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB-C 3.1 , USB 2.0 (powered) , 2 x USB 3.1 Gen 1 , HDMI , LAN , VGA , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
2.02 kg
Sustainability Information
TCO Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
