HP Pro Book 450 G5 Intel Core  i3-7100U 4GB 500GB HDD Windows 10 Pro
Quicklinx: D6H8WS00 Mfr#: 2UB81ET#ABU
  • Core i3
  • IEEE 802.11n
  • Let nothing stand in your way
    Experience the new features of Windows 10 Pro on the thin, light, touch optional HP ProBook 450.
  • Protect your data with multi-factor authentication
    Fortify your security by using multiple factors of authentication including fingerprints and facial recognition.
  • Storage options
    Get the best of both worlds with dual solid-state and hard drive storage options from HP.
  • Outstanding battery life and fast charging
    Battery life that gets you through the workday and beyond. Fast charge 90% in 90 minutes.
  • Stay Connected
    Stay connected with self-healing wireless driver technology and support for the latest global 4G LTE wireless broadband technology.
  • Tested to go the distance
    Stand up to the workload with a ProBook that is designed to pass MIL-STD 810G testing.
HP ProBook 450 G5 Notebook - 15.6" - Intel Core i3 - 7100U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (7th Gen) - 7100U / 2.4 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Input Device
ClickPad
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 14.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
37.6 cm x 26.3 cm x 2.09 cm
2.02 kg
Limited warranty - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i3 (7th Gen) 7100U / 2.4 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Colour Gamut
45% sRGB
Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, dual array microphone
Input
Keyboard, ClickPad
Keyboard Layout
Numeric Keypad
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
Run Time
Up to 14.5 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB 3.1 Gen 1 , USB 2.0 (powered) , LAN , HDMI , Headphone/microphone combo jack , VGA , USB-C 3.1
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
LANDesk Management Suite, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP 3D DriveGuard 6, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, Native Miracast, HP JetAdvantage, HP Wireless Wakeup, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Connection Optimizer, HP BIOSphere Gen4
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, low halogen, ICCP
Localization
2.02 kg
Sustainability Information
TCO Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
