HP Pro 400 G9  mini Core i5 13500T 1.6 GHz 8 GB SSD 256 GB
Quicklinx: HZ4QWS00 Mfr#: 623W7ET#ABU
Processor Type: Core i5
Operating System: Windows 11 Pro
Hard Drive Capacity: 256GB
Storage Type: SSD
Processor Model: I5-13500T
  • Core i5
  • IEEE 802.11n
£596.26 ex VAT
£715.51 inc VAT
The HP Pro Mini 400 provides users with the commercial-grade performance, security, and the flexible deployment capabilities needed for small, varied workspaces. This reliable, ultra-small PC is powered to handle mainstream enterprise and SMBs with an Intel processor and protected with always-on security you can trust.
  • Automatic recovery from firmware attacks
    Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen7 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Work without interruption
    Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen6 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
  • Browse confidently
    Help protect your PC from websites and read only Microsoft Office and PDF attachments with embedded malware, ransomware, or viruses with hardware-enforced security from HP Sure Click.
  • Erase your drive
    HP Secure Erase removes the contents of a hard drive for repurposing or reassignment.
  • Simple PC management
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
HP Pro 400 G9 - mini Core i5 13500T 1.6 GHz - 8 GB - SSD 256 GB - UK
Personal computer - mini
Intel Core i5 (13th Gen) 13500T / 1.6 GHz (up to 4.6 GHz, (14-core)
Processor Main Features
Intel Turbo Boost Technology
Cache Memory
24 MB L3 Cache
Cache Per Processor
24 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 770 Dynamic Video Memory Technology
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.2, Wi-Fi 6E
Keyboard
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Driver Packs, HP Image Assistant (free download), HP Manageability & Integration Kit (free download), HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Sure Sense, HP Sure Admin, HP Client Management Script Library (free download), HP BIOSphere Gen6, Touchpoint Customiser for Commercial, HSA Fusion for Commercial, HSA Telemetry for Commercial, HP Desktop Support Utilities, HP Easy Clean, Absolute Persistence Module, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP PC Hardware Diagnostics Windows, HP Easy Clean Keyboard Driver, HPX for CMIT, HP Sure Start Gen7
17.7 cm x 17.5 cm x 3.42 cm
1.42 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Mini
Built-in Devices
Speaker
Sensors
HP Tamper Lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
1.6 GHz (P-core) / 1.2 GHz (E-core)
Max Turbo Speed
4.6 GHz (P-core) / 3.2 GHz (E-core)
Number of Cores
14-core
CPU Qty
1
Max CPU Qty
1
L2 cache
11.5 MB
CPU Upgradability
Upgradable
Chipset Type
Intel Q670
Cache Memory
Installed Size
L3 Cache - 24 MB
Cache Per Processor
24 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
3200 MHz
Rated Memory Speed
3200 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
NVM Express (NVMe)
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
HDCP Compatible
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 125
Interface (Bus) Type
PCI Express Mini Card (M.2)
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6E AX 211
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.2, IEEE 802.11ax (Wi-Fi 6E)
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.11d, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module) , 1 (total) / 0 (free) x M.2 Card - 2280 (for internal storage)
1 x headphones/microphone (1 in front) (CTIA headset support) , 2 x USB 3.2 Gen 2 (2 in front) (one of them is charging) , 1 x USB-C 3.2 Gen 2x2 (1 in front) (charging) , 1 x USB 3.2 Gen 2 , 2 x DisplayPort 1.4a , 1 x HDMI , 2 x USB 3.2 Gen 1 (wake functionality) , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor, retractable padlock loop
Security Slot Type
Kensington security slot
FIPS 140-2 Level 2, RoHS, WEEE, Common Criteria EAL4+, low halogen
HP Smart Buy
Power adapter
Power Device Name
HP Smart AC Adapter
AC 90-264 V (50/60 Hz)
Power Provided
90 Watt
Efficiency
89% (230VAC), 88% (115VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 11 Pro English
Software
Sustainability Information
TCO Certified
ENERGY STAR Certified
17.7 cm
17.5 cm
3.42 cm
1.42 kg
Shipping Width
49.8 cm
Shipping Depth
23.5 cm
Shipping Height
13.2 cm
Shipping Weight
3.4 kg
10 °C
35 °C
10 - 90% RH (non-condensing)
Warranties (4)
HZ4Q HP Care Pack Next Business Day Hardware Support - Extended serv In Stock £47.07
HZ4Q HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 5 years In Stock £105.53
HZ4Q HP Care Pack Active Care NBD Hardware Support - extended service agreement - 3 years - on-site In Stock £65.90
HZ4Q HP Care Pack Next Business Day Active Care Service with Defective Media Retention - 5 years on-site In Stock £136.51
Accessories (2)
HZ4Q HP B250 Mounting Kit for LCD Display/Thin Client In Stock £33.61
HZ4Q HP DM V4+ VESA Sleeve In Stock £25.22
Monitors (10)
HZ4Q HP P27h G5 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £188.49
HZ4Q HP P22v G5 21.4" 1920x1080 5ms HDMI VGA LED Monitor In Stock £131.20
HZ4Q HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £164.32
HZ4Q HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £320.60
HZ4Q HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £825.46
HZ4Q HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £153.30
HZ4Q HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £73.89
HZ4Q HP E24m G4 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £211.74
HZ4Q HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £110.29
HZ4Q HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort USB IPS LED Monitor In Stock £127.93
Keyboards and Mice (4)
HZ4Q HP 128 Wired Mouse In Stock £8.56
HZ4Q HP 455 Programmable Keyboard - Wireless - UK In Stock £26.46
HZ4Q HP 125 - Mouse - wired - USB - black In Stock £6.26
HZ4Q HP 125 G2 - keyboard - full size - UK - black Input Device In Stock £15.88
Other bundles (56)
HZ4Q HPE DisplayPort DVI-D Adapter In Stock £11.55
HZ4Q HPE DisplayPort to VGA Adapter In Stock £21.98
HZ4Q HP Keyed Cable Lock 10mm In Stock £26.40
HZ4Q Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £240.58
HZ4Q Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £234.68
HZ4Q Poly P5 1080P HD Webcam In Stock £36.52
HZ4Q Poly Savi 8240-M Office Headset In Stock £238.74
HZ4Q Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £124.75
HZ4Q Poly Voyager 4320 UC V4320 C USB-C WW In Stock £103.93
HZ4Q Poly Voyager Focus 2 UC-M USB-A with Stand In Stock £108.52
HZ4Q Poly Blackwire C3225 USB-A Headset In Stock £51.43
HZ4Q Poly EncorePro HW520 Stereo Headset (Noise Cancelling) In Stock £81.71
HZ4Q Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £53.34
HZ4Q Poly EncorePro HW510 Mono Headset (N/C) In Stock £86.11
HZ4Q Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £108.73
HZ4Q Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £98.60
HZ4Q Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £131.93
HZ4Q Poly Savi 7320 Office S7320 Stereo Headset In Stock £236.33
HZ4Q Poly Voyager 4310 UC V4310-M C USB-A WW In Stock £110.75
HZ4Q Poly Sync 20 SY20-M USB-A WW In Stock £72.80
HZ4Q Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £119.34
HZ4Q Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £110.60
HZ4Q Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £121.68
HZ4Q Poly Voyager 4320 UC V4320 C USB-A WW In Stock £97.00
HZ4Q Poly Voyager 4310 UC V4310 C USB-A WW In Stock £113.52
HZ4Q Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £121.68
HZ4Q Poly Sync 10 SY10-M USB-A/C WW In Stock £60.31
HZ4Q Poly EncorePro 525 USB EP525 USB-A Headset In Stock £84.71
HZ4Q Poly EncorePro HW510 Mono Headset (VT) In Stock £73.73
HZ4Q Poly Voyager Focus 2 UC-M USB-C Headset with Stand In Stock £141.12
HZ4Q Poly Sync 40 SY40-M WW In Stock £139.01
HZ4Q Poly Voyager Focus 2 UC USB-A Headset with Stand In Stock £143.47
HZ4Q Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £92.95
HZ4Q Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified In Stock £34.67
HZ4Q Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £33.49
HZ4Q Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £75.19
HZ4Q Poly Spare BT700 Bluetooth USB Adapter In Stock £58.49
HZ4Q Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £49.32
HZ4Q Poly Savi 8420 Office headset - on-ear - DECT / Bluetooth - wireless - active noise cancelling In Stock £164.89
HZ4Q Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager In Stock £91.05
HZ4Q HyperX SoloCast USB Microphone In Stock £50.29
HZ4Q HyperX Pulsefire Core Gaming Mouse In Stock £27.07
HZ4Q HyperX Pulsefire Mat Gaming Mouse Pad In Stock £12.57
HZ4Q Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £65.77
HZ4Q Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £28.00
HZ4Q Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £31.11
HZ4Q Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.33
HZ4Q Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £28.00
HZ4Q Poly EncorePro 515-M headset - on-ear - wired - USB-A - black In Stock £75.67
HZ4Q Poly EncorePro 530 headset - in-ear - wired - Quick Disconnect - black In Stock £81.56
HZ4Q Poly EncorePro 530 - headset - Quick Disconnect In Stock £81.56
HZ4Q Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £121.68
HZ4Q Poly EncorePro HW520D - headset - Quick Disconnect In Stock £107.03
HZ4Q Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £54.64
Storage Type: SSD
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: HP
Price Range Ex VAT: £500 - £750
