HP Presenter MouseRemote control
Quicklinx: DRGTWS00 Mfr#: 2CE30AA#ac3
Run presentations and guide onscreen content with a virtual laser from the palm of your hand, anywhere in the room, or navigate your PC's applications at your desk, with the sophisticated HP Elite Presenter Mouse. It's an ultra-modern, multi-functional accessory that's a pointer and mouse in one.
  • Work the room
    Control and point to presentations from the front or back of the room-without rushing to your PC to change slides-or seated alongside your colleagues, with a wireless range up to 30 ft (10 m) from your Bluetooth -paired PC.
  • Make your point
    Use the real-time virtual laser pointer to highlight Adobe PDF or PowerPoint content onscreen in a conference room and on remote viewer screens when you share your presentation through your collaboration application.
  • Give your mouse a style upgrade
    Turn the mouse and turn heads. Get complete functionality without compromising elegance with a sleek metal-accented device that converts from a flat pointer with basic mouse functions to a comfortable, full-featured mouse with one quick flip.
  • Travel light and in style
    Pop the super-compact presenter into its pouch and your device's bag so it's ready to go anytime you present. Never worry about changing batteries with a design that's rechargeable through a micro USB port and goes to standby when not in use.
  • Built by HP
    Trust your investment in the latest technology with a device that's designed and tested for HP quality and reliability and to complement your HP PCs and mobile devices.
HP Elite Presenter Mouse presentation remote control
Presentation remote control
4.4 cm x 12.5 cm x 1.38 cm
70 g
Radio
Supported Devices
PC multimedia
Wireless Technology
Bluetooth 4.0 LE
Max Operating Distance
9.4 m
Rechargeable
4.4 cm
12.5 cm
1.38 cm
70 g
Radio
Wireless Technology
Bluetooth 4.0 LE
Supported Devices
PC multimedia
9.4 m
Built-in laser pointer, mouse emulation, power on/off, scrolling, 1200 DPI
Connector Type
1 x USB
UL, VCCI, BSMI, GS, NOM, IC, MIC, MOC, FCC, ANATEL, UkrSEPRO, WPC, KC, SRRC, EAC, CITC, RATEL, NCC, RCM, ICASA, TRA, Subtel, NTC, SIRIM, CNC, SDPPI, IMDA
Rechargeable
Run Time (Up To)
2 months
Recharge Time
2 hours
