Run presentations and guide onscreen content with a virtual laser from the palm of your hand, anywhere in the room, or navigate your PC's applications at your desk, with the sophisticated HP Elite Presenter Mouse. It's an ultra-modern, multi-functional accessory that's a pointer and mouse in one.
Work the room
Control and point to presentations from the front or back of the room-without rushing to your PC to change slides-or seated alongside your colleagues, with a wireless range up to 30 ft (10 m) from your Bluetooth -paired PC. -
Make your point
Use the real-time virtual laser pointer to highlight Adobe PDF or PowerPoint content onscreen in a conference room and on remote viewer screens when you share your presentation through your collaboration application. -
Give your mouse a style upgrade
Turn the mouse and turn heads. Get complete functionality without compromising elegance with a sleek metal-accented device that converts from a flat pointer with basic mouse functions to a comfortable, full-featured mouse with one quick flip. -
Travel light and in style
Pop the super-compact presenter into its pouch and your device's bag so it's ready to go anytime you present. Never worry about changing batteries with a design that's rechargeable through a micro USB port and goes to standby when not in use. -
Built by HP
Trust your investment in the latest technology with a device that's designed and tested for HP quality and reliability and to complement your HP PCs and mobile devices.
- HP Elite Presenter Mouse presentation remote control
- Presentation remote control
- 4.4 cm x 12.5 cm x 1.38 cm
- 70 g
- Connectivity Technology
- Radio
- Supported Devices
- PC multimedia
- Wireless Technology
- Bluetooth 4.0 LE
- Max Operating Distance
- 9.4 m
- Battery
- Rechargeable
- Designed For
- ZBook 14u G4, 14u G5, 14u G6, 15 G3, 15 G4, 15 G5, 15 G6, 15u G2, 15u G3, 15u G4, 15u G5, 15u G6, 15v G5, 17 G3, 17 G4, 17 G5, 17 G6, Power G7, Studio G3, Studio G4, Studio G5, Studio G7, Studio G8, Studio x360 G5; ZBook Firefly 14 G7, 14 G8, 15 G7, 15 G8; ZBook Fury 15 G7, 15 G8, 17 G7, 17 G8
- 4.4 cm
- 12.5 cm
- 1.38 cm
- 70 g
- Radio
- Bluetooth 4.0 LE
- Supported Devices
- PC multimedia
- 9.4 m
- Built-in laser pointer, mouse emulation, power on/off, scrolling, 1200 DPI
- Connector Type
- 1 x USB
- UL, VCCI, BSMI, GS, NOM, IC, MIC, MOC, FCC, ANATEL, UkrSEPRO, WPC, KC, SRRC, EAC, CITC, RATEL, NCC, RCM, ICASA, TRA, Subtel, NTC, SIRIM, CNC, SDPPI, IMDA
- Battery
- Rechargeable
- Run Time (Up To)
- 2 months
- Recharge Time
- 2 hours
- Designed For
- HP 250 G5, 250 G6, 255 G5, 255 G6, 470 G8 , HP Chromebook 11 G4 Education Edition, 11 G5, 11 G5 Education Edition, 11 G9 Education Edition, 11MK G9 Education Edition, 13 G1, 14 G7 , HP Chromebook x360 11 G1 Education Edition, 11 G4 Education Edition, 11MK G3 Education Edition , HP Elite Dragonfly , HP Elite x2 1012 G2, 1013 G3, G4, G8 , HP EliteBook 1030 G1, 1040 G4, 1050 G1, 725 G4, 735 G5, 735 G6, 745 G4, 745 G5, 745 G6, 755 G4, 755 G5, 820 G4, 830 G5, 830 G6, 830 G7, 830 G8, 835 G7, 835 G8, 840 Aero G8, 840 G4, 840 G5, 840 G6, 840 G7, 840 G8, 840r G4, 845 G7, 845 G8, 850 G4, 850 G5, 850 G6, 850 G7, 850 G8, 855 G7, 855 G8 , HP EliteBook Folio G1 , HP EliteBook x360 1012 G2, 1020 G2, 1030 G2, 1030 G3, 1030 G4, 1030 G7, 1030 G8, 1040 G5, 1040 G6, 1040 G7, 1040 G8, 830 G5, 830 G6, 830 G7, 830 G8 , HP Mobile Thin Client mt22, mt45, mt46 , HP MX12 Retail Solution , HP Pro x2 612 G2 , HP ProBook 430 G4, 430 G5, 430 G6, 430 G7, 430 G8, 440 G4, 440 G5, 440 G6, 440 G7, 440 G7 Education Edition, 440 G8, 445 G6, 445 G7, 445 G8, 445r G6, 450 G4, 450 G5, 450 G6, 450 G7, 450 G8, 455 G4, 455 G5, 455 G6, 455 G7, 455 G8, 455r G6, 470 G4, 470 G5, 630 G8, 635 Aero G7, 640 G3, 640 G4, 640 G5, 640 G8, 645 G3, 645 G4, 650 G3, 650 G4, 650 G5, 650 G8, 655 G3 , HP ProBook x360 11 G2 Education Edition, 11 G3 Education Edition, 11 G4 Education Edition, 11 G5 Education Edition, 11 G6 Education Edition, 11 G7 Education Edition, 435 G7, 435 G8, 440 G1 , HP Spectre Pro 13 G1, x360 G2 , HP Spectre x360 15-ch006tx , HP Stream Pro 11 G3, 11 G4 Education Edition , HP x2 210 G2 , HP ZBook 14 G2, 14u G4, 14u G5, 14u G6, 15 G2, 15 G3, 15 G4, 15 G5, 15 G6, 15u G2, 15u G3, 15u G4, 15u G5, 15u G6, 15v G5, 17 G3, 17 G4, 17 G5, 17 G6, Create G7, Power G7, Studio G3, Studio G4, Studio G5, Studio G7, Studio G8, Studio x360 G5 , HP ZBook Firefly 14 G7, 14 G8, 15 G7, 15 G8 , HP ZBook Fury 15 G7, 15 G8, 17 G7, 17 G8 , HP ZBook x2 G4 Detachable Workstation
