HP Premium Wireless Mouse
Quicklinx: F6Z9WS00 Mfr#: 1JR31AA#AC3
£38.00 ex VAT
£45.60 inc VAT
Create a sleek, professional, clutter-free workspace and give yourself room to move around with the HP Wireless Premium Mouse, which integrates seamlessly with your HP notebook.
  • Enhance your productivity
    Easily navigate documents and web pages with the accurate, high-performance laser and hyper-fast scrolling.
  • Built-in comfort
    Be comfortable with a soft-touch mouse that naturally fits your left or right hand and resists fingerprints.
  • Smart, efficient battery
    Work without worry with a fast-charging battery that can be conveniently recharged with the included USB cable while you use the mouse. Intelligent standby mode saves battery life and a handy LED indicator alerts you when the battery is low.
  • Wireless connectivity
    Expand your work area with a mouse that works up to 30 ft (10 m) away from your PC through a USB nano-receiver. 2.4 GHz HP Link-5 technology conserves your PC's USB ports by pairing with and connecting to up to five HP Link-5 compatible devices.
  • Rest easy
    Get the reassurance of a one-year limited warranty.
HP Premium - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6.7 cm x 10.7 cm x 3.86 cm
115 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
3
Movement Resolution
1600 dpi
Soft-touch surface
Microsoft Windows 7, Windows 10, Windows 8.x
Mouse
Wireless Receiver
Orientation
6.7 cm
10.7 cm
3.86 cm
115 g
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
3
Movement Resolution
1600 dpi
Soft-touch surface
1 x USB
CSA, UL, TUV GS, VCCI, BSMI, EN55022, SABS, SASO, EN55024, MIC, MOC, FCC, NTRA, ANATEL, UkrSEPRO, WPC, SRRC, CITC, NCC, iDA, BIS, ICASA, TRA, Subtel, CU-EAC, ACMA, EN 301 489-1-17, SIRIM, CONATEL, SDPPI, NRCS
Lithium Ion
400 mAh
Run Time (Up To)
3 months
