HP Premium Wireless Mouse
Quicklinx: F6Z9WS00 Mfr#: 1JR31AA#AC3
Wired / Wireless: Wireless
Colour: Black
More than 50 in stock
£38.58 ex VAT
£46.29 inc VAT
Create a sleek, professional, clutter-free workspace and give yourself room to move around with the HP Wireless Premium Mouse, which integrates seamlessly with your HP notebook.
  • Enhance your productivity
    Easily navigate documents and web pages with the accurate, high-performance laser and hyper-fast scrolling.
  • Built-in comfort
    Be comfortable with a soft-touch mouse that naturally fits your left or right hand and resists fingerprints.
  • Smart, efficient battery
    Work without worry with a fast-charging battery that can be conveniently recharged with the included USB cable while you use the mouse. Intelligent standby mode saves battery life and a handy LED indicator alerts you when the battery is low.
  • Wireless connectivity
    Expand your work area with a mouse that works up to 30 ft (10 m) away from your PC through a USB nano-receiver. 2.4 GHz HP Link-5 technology conserves your PC's USB ports by pairing with and connecting to up to five HP Link-5 compatible devices.
  • Rest easy
    Get the reassurance of a one-year limited warranty.
HP Premium - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6.7 cm x 10.7 cm x 3.86 cm
115 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
3
Movement Resolution
1600 dpi
Soft-touch surface
Microsoft Windows 7, Windows 10, Windows 8.x
HP 340 G7, 470 G8, Z1 G8; Chromebook 11 G9, 14 G7; Chromebook x360; Elite x2; EliteBook 83X G8, 840, 84X G8, 85X G8; EliteBook x360; EliteDesk 800 G8; EliteOne 800 G8; Pro c640 G2, c645; ProBook 44X G8, 45X G8; ProBook x360; Workstation Z1 G8, Z2 G8; ZBook Power G8, Studio G8; ZBook Fury 15 G8
Mouse
Wireless Receiver
Orientation
6.7 cm
10.7 cm
3.86 cm
115 g
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
3
Movement Resolution
1600 dpi
Soft-touch surface
1 x USB
CSA, UL, TUV GS, VCCI, BSMI, EN55022, SABS, SASO, EN55024, MIC, MOC, FCC, NTRA, ANATEL, UkrSEPRO, WPC, SRRC, CITC, NCC, iDA, BIS, ICASA, TRA, Subtel, CU-EAC, ACMA, EN 301 489-1-17, SIRIM, CONATEL, SDPPI, NRCS
Lithium Ion
400 mAh
Run Time (Up To)
3 months
HP 240 G8, 245 G7, 245 G8, 246 G7, 250 G7, 250 G8, 255 G7, 255 G8, 340 G5, 340 G7, 340S G7, 348 G5, 470 G7, 470 G8, Z1 G8 , HP Chromebook 11 G7, 11 G8, 11 G9, 11A G6, 11A G8, 11MK G9, 14 G6, 14 G7, 14A G5 , HP Chromebook Enterprise 14 G6 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G2, 11 G3, 11 G4, 11MK G3, 14 G1 , HP Elite c1030 Chromebook, c1030 Chromebook Enterprise , HP Elite Dragonfly , HP Elite x2 G8 , HP EliteBook 1050 G1, 735 G6, 745 G6, 830 G6, 830 G7, 830 G8, 835 G7, 835 G8, 840 Aero G8, 840 G6, 840 G7, 840 G8, 840r G4, 845 G7, 845 G8, 850 G6, 850 G7, 850 G8, 855 G7, 855 G8 , HP EliteBook x360 1030 G3, 1030 G4, 1030 G7, 1030 G8, 1040 G5, 1040 G6, 1040 G7, 1040 G8, 830 G5, 830 G6, 830 G7, 830 G8 , HP EliteDesk 705 G5, 800 G8, 805 G6 , HP EliteOne 800 G6, 800 G8 , HP Mobile Thin Client mt22, mt45, mt46 , HP Pro c640 Chromebook, c640 G2 Chromebook, c640 G2 Chromebook Enterprise, c645 Chromebook, c645 Chromebook Enterprise , HP ProBook 430 G6, 430 G7, 430 G8, 440 G6, 440 G7, 440 G8, 445 G6, 445 G7, 445 G8, 445r G6, 450 G6, 450 G7, 450 G8, 455 G6, 455 G7, 455 G8, 455r G6, 630 G8, 635 Aero G7, 640 G5, 640 G8, 650 G5, 650 G8 , HP ProBook x360 11 G3, 11 G4, 11 G5, 11 G6, 11 G7, 435 G7, 435 G8, 440 G1 , HP ProDesk 405 G6 , HP ProOne 400 G6, 440 G6 , HP Spectre x360 15-ch006tx , HP Workstation Z1 G6 Entry, Z1 G8, Z1 G8 Entry, Z2 G5, Z2 G8, Z2 Mini G5 , HP ZBook 14u G6 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G6 Mobile Workstation, 17 G6 Mobile Workstation, Create G7, Power G7 Mobile Workstation, Power G8 Mobile Workstation, Studio G5 Mobile Workstation, Studio G7 Mobile Workstation, Studio G8 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation, 15 G7 Mobile Workstation, 15 G8 Mobile Workstation , HP ZBook Fury 15 G7 Mobile Workstation, 15 G8 Mobile Workstation, 17 G7 Mobile Workstation
Colour: Black
Brand: HP
Stock Status: In stock
