Transport your work gear with a stylish and durable laptop bag thoughtfully designed with nylon fabric and a padded compartment for your laptop. The HP Prelude Topload comes with convenient handles or a crossbody strap that helps you carry it the way you want. A pop of color on the zipper is sure to brighten your day every time you open the bag.
Room for the basics
Get a padded compartment for your notebook and internal pockets for your cables, accessories, pens, phone, and more. The top zip closure and exterior flap pocket give you easy access to the items you use most. -
Carry it your way
Carry the case with the double handles or use the comfortable padded crossbody strap to keep your hands free for other tasks. Traveling is a breeze with the luggage pass-through that fits over the handle of most rolling suitcases.
- HP Prelude Top Load - notebook carrying case
- Product Type
- Notebook carrying case
- Black & grey, blue zipper
- Product Material
- 300D cross-dyed woven, 180G air mesh, 210D polyester
- 40 cm x 6 cm x 28.5 cm
- 300 g
- Notebook Compatibility
- 15.6"
- Zippered
- Carrying Strap
- Shoulder carrying strap, top carry handle
- 1-year warranty
- Product Type
- Product Material
- 40 cm
- 6 cm
- 28.5 cm
- 300 g
- Shipping Dimensions (WxDxH) / Weight
- 40 cm x 6 cm x 28.5 cm / 300 g
- 15.6"
- Zippered
- Carrying Strap
- Limited warranty: - 1 year
