Help protect your notebook while you're on the move with the durable nylon HP 15.6 Prelude Top Load case.
Room for the basics
Get a padded compartment for your notebook and internal pockets for your cables, accessories, pens, phone, and more. The top zip closure and exterior flap pocket give you easy access to the items you use most. -
Carry it your way
Carry the case with the double handles or use the comfortable padded crossbody strap to keep your hands free for other tasks. Traveling is a breeze with the luggage pass-through that fits over the handle of most rolling suitcases. -
World-class support
Get the reassurance of a one-year parts replacement limited warranty.
- HP Prelude - notebook carrying case
- Product Type
- Notebook carrying case
- 41 cm x 7.5 cm x 28.5 cm
- 500 g
- Notebook Compatibility
- 15.6"
- Padded, pen holder
- Carrying Strap
- Shoulder carrying strap, top carry handle
- 1-year warranty
- Product Type
- 41 cm
- 7.5 cm
- 28.5 cm
- 500 g
- 15.6"
- Additional Compartments
- Mobile phone
- Carrying Strap
- Limited warranty: - 1 year
