HP PC Mounting Bracket For Monitors
Quicklinx: CKJZWS00 Mfr#: N6N00AA
Customize an altogether better solution with the HP PC Mounting Bracket for Monitors, which lets you attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind select HP Z Displays and EliteDisplays.
Maximize your available work area with a single-footprint solution. Simply attach the bracket to the back of your display, and your PC platform to the bracket. It’s that easy!
Retain the comfort features of your HP Elite Display or HP Z Display. The bracket doesn’t interfere with the monitor’s height adjustment, tilt, swivel or pivot settings.
Get the reassurance of a one-year limited warranty.
Desktop PCs: Compatible with HP Desktop Mini Business PCs and HP Chromebox that have a 100 mm x 100 mm VESA mount.
Thin Clients: Compatible with HP Thin Clients that have a 100 mm x 100 mm VESA mount.
  • Make room
    Maximize your available work area with a single-footprint solution. Simply attach the bracket to the back of your display, and your PC platform to the bracket. It's that easy!
  • Work comfortably
    Retain the comfort features of your HP Elite Display or HP Z Display. The bracket doesn't interfere with the monitor's height adjustment, tilt, swivel or pivot settings.
  • Rest easy
HP - thin client to monitor mounting bracket
Thin client to monitor mounting bracket
11.3 cm 25.59 cm
VESA 100 x 100 mm
1-year warranty
HP HC240, HC270, t420, t430, t430 v2, t530, t540, t628, t630, t640, t730, t740, Z22n, Z23n, Z24n, Z24nf, Z24nq, Z24s, Z25n, Z27n, Z27q; DreamColor Z32x; EliteDisplay E202, E222, E230t, E232, E240, E240c, E240q, E242, E272q; Flexible t520, t620
11.3 cm
25.59 cm
VESA 100 x 100 mm
Limited warranty: - 1 year
HP HC240, HC270, t420, t430, t430 v2, t530, t540, t628, t630, t640, t730, t740, Z22n, Z23n, Z24n, Z24nf, Z24nq, Z24s, Z25n, Z27n, Z27q , HP DreamColor Z32x Professional , HP EliteDisplay E202, E222, E230t, E232, E240, E240c, E240c Video Conferencing Monitor, E240q, E242, E272q , HP Flexible t520, t620, t620 PLUS
