HP is entering the copier industry with disruptive technologies that enable you to offer a superior customer experience. The next generation A3 portfolio - which includes printers and MFPs, LaserJet and PageWide, and color and monochrome - is engineered to provide next generation quality, reliability, security, and solution support. Their speed, ease-of-use, and improved paper handling create a better overall experience that will help your customers drive down cost and boost uptime.
The lowest cost for colour
Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.Print more pages and replace cartridges less often with optional high-yield cartridges.Print even faster – and save even more per page – by setting this printer to General Office mode.Help keep energy costs down with the most efficient MFP in its class. -
Minimal interruptions
Minimise interruptions with an HP PageWide Pro designed for the least maintenance in its class.Wait less, do more with HP's best-in-class speeds – as fast as 55 ppm in colour and black-and-white.Print Microsoft Word and PowerPoint files with a USB port that quickly recognises, formats, and prints.Organise, staple, and collate documents with in-line finishing that helps you save time and look professional. -
Strong security designed to detect and stop attacks
A suite of embedded security features help protect your printer from being an entry point for attacks.Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job.Easily set configuration policies and automatically validate settings for every HP printer in your fleet.Prevent potential attacks and take immediate action with instant notification of security issues. -
Designed with the environment in mind
Conserve resources with an HP PageWide Pro designed to use less energy than any laser MFP in its class.This MFP meets rigorous standards for ISO class 5 cleanrooms – perfect for sensitive environments.Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners.Keep noise to a minimum with an MFP designed to be quiet. Place it near people without disrupting work.
- HP PageWide Pro 772dn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Page wide array (colour)
- Inkjet Technology
- HP PageWide - 4-ink
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 2500 - 15000 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- A4 (210 x 297 mm), A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A3 (297 x 420 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper, punched paper
- Standard Media Capacity
- 1200 sheets
- Max Media Capacity
- 5200 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, scan to SharePoint, scan to PC, scan to OCR
- Power
- AC 120/230 V (50/60Hz)
- 59.8 cm x 53.1 cm x 57.2 cm
- 59.5 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Page wide array - colour
- 75000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 1.5 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Card Copy, collation copy, Auto Color Selection (ACS)
Printing
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 6 (XL), PDF
- First Print Out Time B/W
- 8.25 sec
- First Print Out Time Colour
- 8.25 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 500 pages
- Fax Printing Resolution
- 300 x 300 dpi
- PC Faxing
Fax Machine Features
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling, TAM Interface
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 76.2 x 127 mm, Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm)
- 1200 sheets
- 5200 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 101.6 x 210.8 mm - 215.9 x 297.2 mm , Input tray - 500 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm , Output tray - 500 sheets , Bypass tray - 100 sheets
- Speed Details
- Printing: up to 55 ppm (A4) - B/W draft , Printing: up to 55 ppm (A4) - colour draft , Printing: up to 35 ppm (A4) - B/W normal , Printing: up to 35 ppm (A4) - colour normal , Printing: up to 35 ppm (A4) - B/W (ISO) , Printing: up to 35 ppm (A4) - colour (ISO) , Copying: up to 55 ppm (A4) - B/W draft , Copying: up to 55 ppm (A4) - colour draft , Copying: up to 35 ppm - B/W (ISO) , Copying: up to 35 ppm - colour (ISO) , Scanning: up to 50 ipm (A4) - B/W normal , Scanning: up to 50 ipm (A4) - colour normal , Scanning: up to 35 ipm (A4) - B/W duplex , Scanning: up to 35 ipm (A4) - colour duplex
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
- Operating System Support
- UNIX, Novell NetWare 6, Linux, MS Windows 7, Novell NetWare 6.5, Apple Mac OS X 10.6, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Novell Open Enterprise Server, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Small Business Server 2003 (32/64 bits), MS Windows Server 2008 (32/64-bits), MS Windows Small Business Server 2008 x64 Edition, MS Windows XP 32-bit Edition SP3 or later, Windows 10, MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
- Voltage Required
- 68.7 Watt
- Power Consumption Sleep
- 2.01 Watt
- First Copy Out Time B/W
- 7.75 sec
- First Copy Out Time Colour
- 7.75 sec
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- GS, CCC, EMC, RoHS, REACH, EN 60825-1, EN 62479:2010, IEC 62471:2006, EN 62471:2008, 21 CFR 1040.10, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, LVD 2014/35/EU, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013, ICES-003 issue 6 Class A, Directive 2014/30/UE, CISPR 32, ES 203 021-3 V2.1.2, ES 203 021-1 V2.1.1
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - parts and labour - 1 year - on-site
- 59.8 cm
- 53.1 cm
- 57.2 cm
- 59.5 kg
- Shipping Width
- 79 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 73 cm
- Shipping Weight
- 66.43 kg
- Sound Emission
- 55 dBA (operating)
- 15 °C
- 30 °C
- 20 - 80%
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.74 |
