HP PageWide Pro 477dw Colour Multifunction Printer
Quicklinx: C14HWS00 Mfr#: D3Q20B#A80
Ultimate value and speed - HP PageWide Pro delivers the lowest total cost of ownership and fastest speeds in its class. Get quick two-sided scanning, plus best-in-class security features and energy efficiency.
• Multi-function - print, copy, scan, and more
• Get the lowest total cost of ownership and fastest speeds in its class. Get professional-quality color documents, fast two-sided scanning, plus best-in-class security features and energy efficiency
• For teams of 5–15 people printing; prints up to 6,000 pages/month
• Prints up to 70 pages per minute
Count on exceptional value and the results businesses need – print professional-quality colour documents for the lowest total cost of ownership in its class.
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class. Print professional-quality colour on a variety of papers – perfect for office use. Print more pages and replace cartridges less often, using Original HP PageWide high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology.
Minimise interruptions and downtime with efficient, reliable performance. Conserve resources and use less energy than laser printers, with HP PageWide Technology designed for today’s busy office.
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand. Conserve with HP PageWide Technology – designed to use less energy than any MFP in its class. Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
Best-in-class print speeds, fast printing from sleep mode, and single-pass, two-sided scanning keep productivity on track. Documents are ready fast, so there’s less waiting.
Wait less, do more with unmatched speeds – up to 55 ppm – and the fastest first-page printing in its class. Get fast two-sided scanning directly to email and the cloud with this LDAP-enabled MFP. Manage tasks from a 10.9 cm (4.3-inch) touchscreen. Print Microsoft® Word and PowerPoint® files from USB. Print from your mobile device with Wi-Fi Direct and NFC touch-to-print technology – no network needed.
Help protect your fleet, data, and documents with best-in-class security and fleet management features. Help secure important information and get the tools you need to work efficiently and confidently.
Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job. Regulate colour use and reduce printing costs with HP Colour Access Control. Help keep your printer secure – from boot up to shutdown – with secure boot and secure code integrity validation.
  • HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
    HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class.
  • Colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • Easy mobile printing from HP
    Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
HP PageWide Pro 477dw - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Page wide array (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
750 - 4500 pages
Max Copying Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper, punched paper
Standard Media Capacity
500 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, access point mode, scan to SharePoint, scan to PC, scan to OCR
AC 120 V (50/60Hz)
53 cm x 40.7 cm x 46.7 cm
22.15 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Page wide array - colour
50000 pages
750 - 4500 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
786 MB
Max Supported Memory
786 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 6 (XL), PDF
Automatic Duplexing
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
300 x 300 dpi
PC Faxing
Fax Machine Features
Speed Dialing
199 station(s)
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling, TAM Interface
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm)
500 sheets
300 sheets
ADF - 50 sheets size: 101.6 x 210.8 mm - 215.9 x 297.2 mm , Input tray - 500 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm , Output tray - 300 sheets
Speed Details
Scanning: up to 25 ipm - B/W , Scanning: up to 25 ipm - colour , Printing: up to 55 ppm (A4) - B/W draft , Printing: up to 55 ppm (A4) - colour draft , Printing: up to 40 ppm - B/W (ISO) , Printing: up to 40 ppm - colour (ISO) , Copying: up to 40 ppm - B/W (ISO) , Copying: up to 40 ppm - colour (ISO) , Copying: up to 55 ppm (A4) - B/W draft , Copying: up to 55 ppm (A4) - colour draft , Printing: up to 55 ppm (Letter A) - B/W draft , Printing: up to 55 ppm (Letter A) - colour draft , Copying: up to 55 ppm (Letter A) - B/W draft , Copying: up to 55 ppm (Letter A) - colour draft
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 2 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
LDAP, SSL, LEAP, TLS, WPA2, 802.1x, WPA2-PSK, EAP-TLS, PEAP
Operating System Support
UNIX, Novell NetWare 6, Linux, MS Windows 7, Novell NetWare 6.5, Apple Mac OS X 10.6, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Novell Open Enterprise Server, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Small Business Server 2003 (32/64 bits), MS Windows Server 2008 (32/64-bits), MS Windows Small Business Server 2008 x64 Edition, MS Windows XP 32-bit Edition SP3 or later, Windows 10, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
AC 120 V (50/60Hz)
100 Watt
Power Consumption Standby
10 Watt
Power Consumption Sleep
4.8 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 3000 pages - HP 913 , 1 x ink cartridge (cyan) - up to 1500 pages - HP 913 , 1 x ink cartridge (magenta) - up to 1500 pages - HP 913 , 1 x ink cartridge (yellow) - up to 1500 pages - HP 913
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year - on-site
53 cm
40.7 cm
46.7 cm
22.15 kg
Shipping Width
60 cm
Shipping Depth
49.5 cm
Shipping Height
59.4 cm
Shipping Weight
26.39 kg
Sound Emission
56 dBA (operating)
15 °C
30 °C
20 - 80%
Ink (14)
C14H HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
C14H HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £4.92
C14H HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.43
C14H HP 973X High Yield Black Original PA In Stock £96.58
C14H HP 973X High Yield Cyan Original PAG In Stock £91.63
C14H HP 973X High Yield Yellow Original P In Stock £91.63
C14H HP 913A Black Original PageWide Cartridge In Stock £62.91
C14H HP 913A Cyan Original PageWide Cartridge In Stock £64.70
C14H HP 913A Magenta Original PageWide Cartridge In Stock £64.70
C14H HP 913A Yellow Original PageWide Cartridge In Stock £64.70
C14H HP 973X High Yield Black Original PageWide Cartridge In Stock £96.58
C14H HP 973X High Yield Cyan Original PageWide Cartridge In Stock £91.63
C14H HP 973X High Yield Magenta Original PageWide Cartridge In Stock £91.63
C14H HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
Other bundles (1)
C14H C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
