Ultimate value and speed - HP PageWide Pro delivers the ultra-low total cost of ownership and incredibly fast speeds. Get professional-quality color plus ultimate security features and energy efficiency.
Count on exceptional value and the results businesses need – print professional-quality colour documents for the lowest total cost of ownership in its class.
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class. Print professional-quality colour on a variety of papers – perfect for office use. Print more pages and replace cartridges less often, using Original HP PageWide high-yield cartridges. Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology. Keep productivity on track with best-in-class speeds and fast printing from sleep mode. Documents are ready fast, so there’s less waiting.
Wait less, do more with best-in-class speeds – as fast as 55 ppm in colour and black-and-white. Grab pages and go – without waiting. This device wakes up and prints fastest in its class. Print directly from your mobile device to your Wi-Fi Direct® printer – without accessing the company network. Minimise interruptions and downtime with efficient, reliable performance. Conserve resources and use less energy than laser printers, with HP PageWide Technology designed for today’s busy office.
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand. Conserve with HP PageWide Technology – designed to use less energy than any printer in its class. Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges. Help protect your fleet, data, and documents with best-in-class security and fleet management features. Help secure important information and get the tools you need to work efficiently and confidently.
Help protect your investment and extend capabilities as your needs grow, with a portfolio of solutions. Help keep your printer secure – from boot up to shutdown – with secure boot and secure code integrity validation.
HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class. -
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
2-sided printing
Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
- HP PageWide Pro 452dw - printer - colour - page wide array
- Printer Type
- Workgroup printer - page wide array - colour
- 16.4 kg
- Localisation
- EMEA (excluding Israel, Saudi Arabia)
- Ink Palette Supported (Colours)
- 4-ink
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W , Up to 40 ppm - colour , Up to 55 ppm - black draft , Up to 55 ppm - colour draft
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 2"
- RAM Installed (Max)
- 512 MB (512 MB) integrated
- Language Simulation
- PostScript 3, PCL 6, PCL XL, PDF
- Media Type
- Envelopes, greeting cards, labels, plain paper, photo paper, glossy photo paper, heavy-weight paper, cards, matt photo paper, bond paper, glossy/satin photo paper, recycled paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper
- Total Media Capacity
- 500 sheets
- Media Handling
- 500-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 750 - 4500 pages
- Networking
- Radio access point
- Printer Features
- HP EasyColor
- System Requirements
- UNIX, Linux, Novell NetWare 6, Novell NetWare 6.5, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Standard x64 Edition, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Compute Cluster Server, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Microsoft Windows Server 2008 Standard x64 Edition, Citrix Presentation Server 4.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows Small Business Server 2008 x64 Edition, Microsoft Windows Small Business Server 2011, Citrix XenApp 6.0 64-bit, Citrix XenServer 5.6, Citrix XenDesktop 5.5, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Citrix XenApp, Microsoft Windows Small Business Server 2003 (32/64 bits), Citrix XenApp 6.5, Microsoft Windows XP SP2 (32 bit) or later, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2008 R2 Enterprise (64-bit), Microsoft Windows Server 2008 R2 Standard (64-bit), Microsoft Windows XP SP3 (32 bit) or later, Apple OS X 10.10 Yosemite, Microsoft Windows Server 2003 R2 Standard Edition (32-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit)
- 1-year warranty
- 53.1 cm x 40.1 cm x 37.8 cm
- Printer Type
- Localisation
Printer
- 4-ink
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- 2 inch (5.08 cm) monochrome graphics display
- 2"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 7 sec
- Fonts Included
- 1
- Printer Features
- HP EasyColor
- Media Handling
RAM
- 512 MB / 512 MB (max)
- Technology / Form Factor
- Integrated
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm)
- 500 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 300 sheets
Duty Cycle
- 50000 pages
- 750 - 4500 pages
- Networking
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 3000 pages - HP 973A , 1 x ink cartridge (cyan) - HP 973A , 1 x ink cartridge (magenta) - HP 973A , 1 x ink cartridge (yellow) - HP 973A
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 100 Watt
- Power Consumption Stand by
- 9.5 Watt
- Power Consumption Sleep
- 4.5 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, Printer utility for Mac, Bing Toolbar, HP Software Update
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - HD 2 GB , Windows XP SP3 - 233 MHz HD 850 MB , MacOS 8.6 or later - HD 1 GB
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site , Technical support - e-mail consulting - 1 year
- 15 °C
- 30 °C
- 20 - 80%
- Sound Emission (Operating)
- 56 dBA
- 53.1 cm
- 40.1 cm
- 37.8 cm
- 16.4 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 49.5 cm
- Height (Shipping)
- 47.7 cm
- Weight (Shipping)
- 20.2 kg
Ink (12)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.39 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.17 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.90 |
HP 973X High Yield Black Original PA | In Stock | £117.69 |
HP 973X High Yield Cyan Original PAG | In Stock | £111.66 |
HP 973X High Yield Yellow Original P | In Stock | £111.67 |
HP 913A Black Original PageWide Cartridge | In Stock | £66.09 |
HP 913A Cyan Original PageWide Cartridge | In Stock | £70.00 |
HP 913A Yellow Original PageWide Cartridge | In Stock | £70.01 |
HP 973X High Yield Black Original PageWide Cartridge | In Stock | £117.69 |
HP 973X High Yield Cyan Original PageWide Cartridge | In Stock | £111.66 |
HP 973X High Yield Magenta Original PageWide Cartridge | In Stock | £111.67 |
Other bundles (2)
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.84 |
HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm | In Stock | £14.27 |
