Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Power productivity with fast two-sided printing.
Professional colour, breakthrough total cost
Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class.Print professional-quality colour on a variety of papers – perfect for office use.Print up to 2.5x more pages and replace less often than standard cartridges with high-yield options.Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology. -
Enterprise productivity at unmatched speeds
Wait less, print more with unmatched speeds – up to 75 ppm – and superfast first-page printing.Get fast two-sided scanning – up to 45 ipm – directly to email, USB, and network folders.Optional touch-to-print and encrypted wireless direct help keep mobile printing easy and protected.Queue jobs, embed solutions, and use multiple functions at once – scan, copy, or fax while someone is printing. -
Unparalleled fleet security and management
Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.Help protect data on the MFP and in transit, using embedded security features and 256-bit encryption.Help build business efficiency with HP Web Jetadmin, plus deploy over HP and 180 third-party solutions.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager. -
Proven technology
Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand.Print up to 16,000 colour pages and up to 20,000 black-and-white pages – and go longer between replacements.Conserve with HP PageWide Technology – designed to use less energy than any MFP in its class.Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
- HP PageWide Enterprise Color MFP 586f - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Page wide array (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 75 ppm (mono) / up to 75 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 76 x 127 mm (min) - 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - A4 (210 x 297 mm), 216 x 356 mm (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, tri-fold paper, soft gloss photo paper
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 2050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, save to network folder, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 53 cm x 56.4 cm x 52.9 cm
- 32.3 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Page wide array - colour
- 80000 pages
- 2000 - 7500 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2 GB
- Max Supported Memory
- 2.75 GB
- Supported Flash Memory
- USB flash drive
Copying
- Maximum Copies
- 9999
- Copying Features
- Collation copy
Printing
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- First Print Out Time B/W
- 7.1 sec
- First Print Out Time Colour
- 7.3 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Fax Printing Resolution
- 400 x 400 dpi
Fax Machine Features
- Broadcast Transmission
- 210 stations
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 127 x 127 mm, 216 x 356 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 550 sheets
- 2050 sheets
- 50 sheets
- 300 sheets
- ADF - 100 sheets weight: 45 g/m² - 199 g/m² , Bypass tray - 50 sheets , Input tray - 500 sheets , Output tray - 300 sheets
- Speed Details
- Printing: up to 50 ppm (A4) - B/W , Printing: up to 50 ppm (A4) - colour , Printing: up to 25 ppm (A4) - B/W duplex , Printing: up to 25 ipm (A4) - colour duplex , Scanning: up to 44 ppm - B/W , Scanning: up to 40 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 host (internal) , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Ubuntu Linux 10 - 14, Apple Mac OS X 10.9 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- 62 Watt
- Power Consumption Standby
- 24 Watt
- Power Consumption Sleep
- 8.5 Watt
- Consumables Included
- 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN 55022:2010 Class A, CISPR 22:2008, EN55024:2010
- ENERGY STAR Certified
- Blue Angel Compliant
- 53 cm
- 56.4 cm
- 52.9 cm
- 32.3 kg
- Shipping Weight
- 40.4 kg
- 15 °C
- 30 °C
- 20 - 60%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £11.76 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £12.13 |
