Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Power productivity with seamless workflow features.
HP PageWide: Not Laser. Not inkjet. It's the best of both. A new alternative for business printing
HP PageWide is designed with fewer moving parts. The stationary, page-width print bar enables unmatched speeds, improved reliability, and fewer replacement parts, all with professional print quality at the lowest total cost of operation in its class. -
Low cost, affordable printing
Print what you need affordably using low cost Original HP ink cartridges. -
Fast FPOT from ready – as fast as 7.1 seconds
This printer wakes up fast and prints your first page as quickly as 7.1 seconds. -
Fast FPOT from ready-as fast as 7.1 seconds
HP Sure Start, intrusion detection, and whitelisting
Rest assured that your fleet is covered, with award-winning HP Imaging and Printing Security Center.
- HP PageWide Enterprise Color Flow MFP 586z - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Page wide array (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 50 ppm (mono) / up to 50 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 76 x 127 mm (min) - 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - A4 (210 x 297 mm), 216 x 356 mm (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, tri-fold paper, soft gloss photo paper
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 2050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, save to network folder, pull-out keyboard, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 53 cm x 56.4 cm x 52.9 cm
- 32.3 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Page wide array - colour
- 80000 pages
- 2000 - 7500 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 2 GB
- Max Supported Memory
- 2.75 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Collation copy
Printing
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- First Print Out Time B/W
- 7.1 sec
- First Print Out Time Colour
- 7.3 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Fax Printing Resolution
- 400 x 400 dpi
Fax Machine Features
- Broadcast Transmission
- 210 stations
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, 127 x 127 mm, 216 x 356 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 550 sheets
- 2050 sheets
- 50 sheets
- 300 sheets
- ADF - 100 sheets weight: 45 g/m² - 199 g/m² , Bypass tray - 50 sheets , Input tray - 500 sheets , Output tray - 300 sheets
- Speed Details
- Scanning: up to 45 ppm - B/W , Scanning: up to 45 ppm - colour , Printing: up to 50 ppm - B/W (ISO) , Printing: up to 50 ppm - colour (ISO) , Printing: up to 25 ppm (A4) - B/W duplex , Printing: up to 25 ipm (A4) - colour duplex , Copying: up to 50 ppm - B/W (ISO) , Copying: up to 50 ppm - colour (ISO) , Printing: up to 75 ppm (A4) - B/W draft , Printing: up to 75 ppm (A4) - colour draft , Printing: up to 75 ppm (Letter A) - B/W draft , Printing: up to 75 ppm (Letter A) - colour draft
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A , 2 x USB 2.0 host (internal) , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Ubuntu Linux 10 - 14, Apple Mac OS X 10.9 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- 62 Watt
- Power Consumption Standby
- 24 Watt
- Power Consumption Sleep
- 8.5 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 53 cm
- 56.4 cm
- 52.9 cm
- 32.3 kg
- Shipping Weight
- 40.4 kg
- 15 °C
- 30 °C
- 20 - 60%
Ink (17)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.68 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £4.91 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.41 |
HP 981A Black original PageWide ink cartridge | In Stock | £61.51 |
HP 981A Yellow original PageWide ink cartridge | In Stock | £89.90 |
HP 981A Magenta original PageWide ink cartridge | In Stock | £89.90 |
HP 981A Cyan original PageWide ink cartridge | In Stock | £89.90 |
HP 981X High Yield Magenta Original PageWide | In Stock | £112.60 |
HP INK CARTRIDGE 981Y CYAN | In Stock | £171.74 |
HP INK CARTRIDGE 981Y MAGENTA | In Stock | £171.74 |
HP INK CARTRIDGE 981Y YELLOW | In Stock | £171.74 |
HP INK CARTRIDGE 981Y BLACK | In Stock | £132.49 |
HP 981X High Yield Yellow Original PageWide | In Stock | £117.77 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.69 |
HP Waste ink collector - for PageWide Enterprise Color MFP 586 | In Stock | £52.51 |
HP 981X High Yield Cyan Original PageWide Cartridge | In Stock | £117.77 |
HP 981X High Yield Black Original PageWide Cartridge | In Stock | £86.36 |
Other bundles (2)
HP Foreign Interface Harness (FIH) | In Stock | £77.37 |
HP Paper Feeder And Stand Media Tray Feeder 500 Sheets | In Stock | £793.20 |
