HP PageWide Enterprise Colour 556dn
Quicklinx: C15DWS00 Mfr#: G1W46A#B19
Ultimate value for today's enterprise – HP PageWide Technology delivers the fastest speeds and deepest security for the lowest total cost of ownership in its class. Count on productivity and unparalleled multi-level security.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Professional colour, breakthrough total cost
    Results you expect and lasting value – breakthrough total cost of ownership, the lowest in its class.Print professional-quality colour on a variety of papers – perfect for office use.Print up to 2.5x more pages and replace less often than standard cartridges with high-yield options.Spend less time and budget on scheduled maintenance with streamlined HP PageWide Technology.
  • Enterprise productivity at unmatched speeds
    Wait less and do more with best-in-class speeds – as fast as 75 ppm in colour and black-and-white.Grab the documents you need and go. This device prints first pages in as fast as 7.1 seconds.Optional NFC touch-to-print and encrypted wireless direct help keep mobile printing easy and protected.Equip employees to breeze through tasks with the adjustable 10.9 cm (4.3-inch) colour touchscreen.
  • Unparalleled fleet security and management
    Embedded features detect security threats and heal your printer, protecting it from boot up to shutdown.Help protect data on the printer and in transit, using more than 100 embedded security features.Help build business efficiency with HP Web Jetadmin, plus deploy over HP and 175 third-party solutions.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
  • Proven technology
    Minimise downtime with HP PageWide Technology that delivers reliable performance businesses demand.Print up to 16,000 colour pages and up to 20,000 black-and-white pages – and go longer between replacements.Conserve with HP PageWide Technology – designed to use less energy than any printer in its class.Get professional-quality colour documents and the performance you expect with Original HP PageWide cartridges.
HP PageWide Enterprise Color 556dn - printer - colour - page wide array
Printer Type
Workgroup printer - page wide array - colour
22.2 kg
English, German, French, Italian, Spanish / Europe
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 75 ppm - black draft - A4 (210 x 297 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - colour draft - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm) , Up to 38 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Preview Screen Size
4.3"
1.2 GHz
RAM Installed (Max)
1280 MB ( 2304 MB )
Language Simulation
PostScript 3, PCL 6, PDF 1.4
Media Type
Envelopes, greeting cards, labels, plain paper, glossy photo paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, satin photo paper, glossy brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper
Total Media Capacity
550 sheets
Media Handling
500-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 - 7500 pages
Print server
Printer Features
HP ePrint, Mopria certified
AC 120/230 V
UNIX, Android, Ubuntu 10.04, Microsoft Windows XP (32/64 bits) SP3, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Red Hat Fedora 17, Ubuntu 12.10, Apple MacOS X 10.9, Red Hat Fedora 18, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Vista / 7 / 8 / 8.1 / 10 (32/64 bits), Apple MacOS X 10.11, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1, Windows 10 Mobile
1 year warranty
53 cm x 46.3 cm x 45.7 cm
Printer Type
Printer
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
4.3"
Wired
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.1 sec
First Print Out Time Colour
7.3 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
1280 MB / 2304 MB (max)
Media Handling
Media Type
Envelopes, greeting cards, labels, plain paper, heavy-weight paper, matt photo paper, bond paper, recycled paper, satin photo paper, glossy brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, soft gloss photo paper, punched paper
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 216 x 297 mm, 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, 102 x 210 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm)
550 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 500 sheets - Legal (216 x 356 mm)
Output Trays Capacity
300 sheets
Duty Cycle
80000 pages
2000 - 7500 pages
Print server
Remote Management Protocol
Telnet, SNMP 3, IPP, HTTP, HTTPS, TFTP, SLP
Security Protocols & Features
SSL, Apple Bonjour, TLS, IPsec, 802.1x, WPA2-Enterprise
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x ink cartridge ( black ) , 1 x ink cartridge ( cyan ) , 1 x ink cartridge ( magenta ) , 1 x ink cartridge ( yellow )
AirPrint, Google Cloud Print 2.0
UL, cUL, GS, Directive 2006/95/EC, EN 62479:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
52 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
6.3 Watt
Software Included
Drivers & Utilities, HP Web JetAdmin, HP Software Update
System Requirements Details
HD 200 MB , MacOS - HD 1 GB
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
30 °C
20 - 80%
Sound Emission (Operating)
55 dBA
53 cm
46.3 cm
45.7 cm
22.2 kg
Width (Shipping)
60.3 cm
Depth (Shipping)
56.5 cm
Height (Shipping)
55.3 cm
Weight (Shipping)
27.5 kg
Ink (17)
C15D HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
C15D HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £4.92
C15D HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.43
C15D HP 981A Black original PageWide ink cartridge In Stock £61.64
C15D HP 981A Yellow original PageWide ink cartridge In Stock £90.09
C15D HP 981A Magenta original PageWide ink cartridge In Stock £90.09
C15D HP 981A Cyan original PageWide ink cartridge In Stock £90.09
C15D HP 981X High Yield Magenta Original PageWide In Stock £118.01
C15D HP INK CARTRIDGE 981Y CYAN In Stock £183.16
C15D HP INK CARTRIDGE 981Y MAGENTA In Stock £172.11
C15D HP INK CARTRIDGE 981Y YELLOW In Stock £172.11
C15D HP INK CARTRIDGE 981Y BLACK In Stock £132.78
C15D HP 981X High Yield Yellow Original PageWide In Stock £118.01
C15D HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
C15D HP Waste ink collector - for PageWide Enterprise Color MFP 586 In Stock £52.51
C15D HP 981X High Yield Cyan Original PageWide Cartridge In Stock £118.01
C15D HP 981X High Yield Black Original PageWide Cartridge In Stock £86.54
Other bundles (3)
C15D HP Foreign Interface Harness (FIH) In Stock £77.37
C15D HP Paper Feeder And Stand Media Tray Feeder 500 Sheets In Stock £793.20
C15D HP Electronic HP Care Pack Next Business Day Hardware Support In Stock £349.09
