HP PageWide 755DN Colour 55ppm Printer
Quicklinx: DZXJWS00 Mfr#: 4PZ47A#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Max Print Speed: 55ppm
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£1,649.25 ex VAT
£1,979.10 inc VAT
Business moves fast, and slowing down means falling behind. It's why HP built the next generation of HP PageWide – to power productivity with a smart, efficient design that delivers the lowest colour cost, maximum uptime, and strong security.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • The lowest cost for colour
    Get the quality you expect with HP PageWide Technology that delivers the lowest cost per colour page.Print even faster – and save even more per page – by setting this printer to General Office mode.Help keep energy costs down with the most efficient printer in its class.
  • Minimal interruptions
    Minimise interruptions with an HP PageWide printer designed for the least maintenance in its class.Print speeds up to 50% faster than competitors – as fast as 55 ppm in colour and black-and-white.Print Microsoft Word and PowerPoint files with a USB port that quickly recognises, formats, and prints.Equip this HP PageWide printer with a variety of accessories to meet the needs of your office.
  • Strong security designed to detect and stop attacks
    A suite of embedded security features help protect this printer from being an entry point for attacks.Help ensure the security of confidential information. Enter a PIN at the device to retrieve your print job.Easily set configuration policies and automatically validate settings for every HP printer in your fleet.Thwart potential attacks and take immediate action with instant notification of security issues.
  • Designed with the environment in mind
    Conserve resources with HP PageWide – designed to use less energy than any laser printer in its class.This printer meets rigorous standards for ISO class 5 cleanrooms – perfect for sensitive environments.Help reduce your impact. Count on easy cartridge recycling at no charge through HP Planet Partners.Keep noise to a minimum with a printer designed to be quiet. Place it near people without disrupting work.
HP PageWide Color 755dn - printer - colour - page wide array
Printer Type
Workgroup printer - page wide array - colour
22.15 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP PageWide
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 457.2 mm
Print Speed
Up to 55 ppm - black draft - A4 (210 x 297 mm) , Up to 55 ppm - colour draft - A4 (210 x 297 mm) , Up to 35 ppm - B/W (ISO/IEC 24734) , Up to 35 ppm - colour (ISO/IEC 24734) , Up to 35 ppm - black normal - A4 (210 x 297 mm) , Up to 35 ppm - colour normal - A4 (210 x 297 mm) , Up to 24 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ipm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
Preview Screen Size
4.3"
1.2 GHz
Language Simulation
PostScript 3, PCL 6, PCL XL, PDF
Media Type
Envelopes, greeting cards, labels, plain paper, photo paper, cards, bond paper, recycled paper, brochure paper, tri-fold brochure paper, extra heavy-weight paper, light-weight paper, punched paper
Total Media Capacity
550 sheets
Media Handling
500-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
2500 - 15000 pages
Printer Features
HP EasyColor
AC 120/230 V
UNIX, Linux, Novell NetWare 6, Novell NetWare 6.5, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Enterprise x64 Edition, Microsoft Windows Server 2003 R2 Standard x64 Edition, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Compute Cluster Server, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Microsoft Windows Server 2008 Standard x64 Edition, Citrix Presentation Server 4.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows Small Business Server 2008 x64 Edition, Microsoft Windows Small Business Server 2011, Citrix XenApp 6.0 64-bit, Citrix XenServer 5.6, Citrix XenDesktop 5.5, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Citrix XenApp, Microsoft Windows Small Business Server 2003 (32/64 bits), Citrix XenApp 6.5, Microsoft Windows XP SP2 (32 bit) or later, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2008 R2 Enterprise (64-bit), Microsoft Windows Server 2008 R2 Standard (64-bit), Microsoft Windows XP SP3 (32 bit) or later, Apple OS X 10.10 Yosemite, Microsoft Windows Server 2003 R2 Standard Edition (32-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit)
1-year warranty
60.4 cm x 65.2 cm x 46.7 cm
Printer Type
Printer
Inkjet Technology
HP PageWide
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
4.3"
Wired
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8.2 sec
First Print Out Time Colour
8.2 sec
Language Simulation
Fonts Included
1
Printer Features
HP EasyColor
Media Handling
1.2 GHz
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
76 mm x 127 mm
216 mm x 457.2 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), 102 x 210 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm)
Media Weight
60 g/m² - 300 g/m²
550 sheets
Media Feeders
1 x automatic - 50 sheets - A3 (297 x 420 mm) , 1 x automatic - 500 sheets - A3 (297 x 420 mm)
Output Trays Capacity
300 sheets
Duty Cycle
75000 pages
2500 - 15000 pages
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS, IPPS, SLP
Security Protocols & Features
LDAP, LEAP, WPA, 802.1x, PING, ARP, Wi-Fi Direct, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
RoHS, REACH, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EN 301 489-17 V2.2.1 (2012-09), IEC 61000-4-11:2004, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 301 489-1 V1.9.2:2011, EN 301 489-17 V2.2.1:2012, EN 301 489-1 V1.9.2 (2011-09), EMC 2014/30/EU, EN 62311:2008, FCC Part 15 Class B, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, IEC 62311:2007, LVD 2014/35/EU, EN 300 893, EN 300 328 V1.9.1, ICES-003:2004 Class B, VCCI V-3/2015.04 Class B, CISPR 32 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 55022:2010 Class B
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
535 Watt
Power Consumption Sleep
0.97 Watt
Software Included
Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, Printer utility for Mac, Bing Toolbar, HP Software Update
System Requirements Details
Windows 7/8/8.1/10 - HD 2 GB , Windows XP SP3 - 233 MHz HD 850 MB , MacOS 8.6 or later - HD 1 GB
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site , Technical support - phone consulting - 1 year
15 °C
30 °C
20 - 80%
Sound Emission (Operating)
54 dBA
60.4 cm
65.2 cm
46.7 cm
22.15 kg
Width (Shipping)
79 cm
Depth (Shipping)
76 cm
Height (Shipping)
62.3 cm
Weight (Shipping)
54.8 kg
Type: Printer
Output Type: Colour
Max Paper Size: A3 (297 x 420 mm)
Brand: HP
Price Range Ex VAT: 1500+
