Your basket is empty
HP PageWide 377dw MFP
Love it or your money back!
Cashback
Limited Time Offer
Quicklinx: C5T6WS00 Mfr#: J9V80B#A80
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Technology: Laser
18 in stock
£253.61 ex VAT
£304.33 inc VAT
Faster than any colour MFP in its class, HP PageWide delivers professional-quality colour documents, fast two-sided scanning, and best-in-class energy efficiency – all at a low purchase price.
HP PageWide MFP 377dw - multifunction printer (colour)
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
40000 pages
Recommended Monthly Volume
500 - 3000 pages
Max Copying Speed
Up to 45 ppm (mono) / up to 45 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper, punched paper
Standard Media Capacity
500 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, HP EasyColor, Mobile Printing, access point mode, scan to SharePoint, scan to PC, scan to OCR
AC 120/230 V (50/60Hz)
53 cm x 40.7 cm x 46.7 cm
22.15 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
40000 pages
500 - 3000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
768 MB
Max Supported Memory
768 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL XL, PDF
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Resolution
300 x 300 dpi
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
20 stations
Delayed Transmission
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending, fax polling, TAM Interface
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 127 x 178 mm, 76.2 x 127 mm, Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm)
500 sheets
300 sheets
ADF - 50 sheets size: 101.6 x 210.8 mm - 215.9 x 297.2 mm , Input tray - 500 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm , Output tray - 300 sheets
Speed Details
Printing: up to 45 ppm (A4) - B/W draft , Printing: up to 45 ppm (A4) - colour draft , Printing: up to 30 ppm - B/W (ISO) , Printing: up to 30 ppm - colour (ISO) , Copying: up to 45 ppm (A4) - B/W draft , Copying: up to 45 ppm (A4) - colour draft , Copying: up to 30 ppm - B/W , Copying: up to 30 ppm - colour , Scanning: up to 25 ipm (A4) - B/W , Scanning: up to 25 ipm (A4) - colour
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
LDAP, SSL, LEAP, TLS, WPA2, 802.1x, WPA2-PSK, EAP-TLS, PEAP
Operating System Support
UNIX, Novell NetWare 6, Linux, MS Windows 7, Novell NetWare 6.5, Apple Mac OS X 10.6, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Novell Open Enterprise Server, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Small Business Server 2003 (32/64 bits), MS Windows Server 2008 (32/64-bits), MS Windows Small Business Server 2008 x64 Edition, MS Windows XP 32-bit Edition SP3 or later, Windows 10, MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
100 Watt
Power Consumption Standby
9.5 Watt
Power Consumption Sleep
4.5 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 3000 pages - HP 913 , 1 x Cartridge (cyan) - HP 913 , 1 x Cartridge (magenta) - HP 913 , 1 x Cartridge (yellow) - HP 913
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year - on-site , Technical support - phone consulting - 1 year
53 cm
40.7 cm
46.7 cm
22.15 kg
Shipping Width
80.2 cm
Shipping Depth
69.4 cm
Shipping Height
48.5 cm
Shipping Weight
26.39 kg
Sound Emission
56 dBA (operating)
15 °C
30 °C
20 - 80%
Ink (3)
C5T6 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £9.82
C5T6 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £12.38
C5T6 HP Professional Glossy Inkjet Paper-50 sheet/A4/210 x 297 mm In Stock £9.64
Other bundles (4)
C5T6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
C5T6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
C5T6 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
C5T6 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Brand: HP
Price Range Ex VAT: 150 - 300
