Brand
HP P24v G4 23.8" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: G28SWS00 Mfr#: 9TT78AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), HDMI
£145.00 ex VAT
£174.00 inc VAT
Tackle your daily to-do list and multi-task across multiple windows on the on the large-screen HP P24v G4 Monitor that adjusts to your comfort needs and delivers Full HD picture quality with clear 178° sightlines.
  • Crisp image clarity for all your content
    Get lifelike color, sharp details, and a great view of everything you do, wherever you sit or stand, on a 23.8" diagonal Full HD IPS monitor with 178° viewing angles.
  • Modern connectivity
    Conveniently and quickly connect to your devices and additional monitors through the HDMI and VGA ports, no dongles required.
  • Limitless views
    See more of your actual screen and less of its borders with the 3-sided micro-edge design that also makes dual-monitor setups a virtually seamless dream with no bezel interruptions.
HP P24v G4 - P-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class D
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
13.2 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare 3H hardness
Voltage
53.96 cm x 18.61 cm x 40.5 cm
3.46 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV, VCCI, C-Tick, BSMI, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, WEEE, cTUVus, TUV Bauart, E-Standby, CEC, UkrSEPRO, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, Energy-using Products (EuP) Lot 5, NOM-NYCE, ICE, Australian-New Zealand MEPS, Vietnam MEPS, Mexico MEPS, South Africa MEPS, Ukraine Energy Label, TGM, Japan PC Green Label
3-year warranty
Display Type
Energy Class
Class D
24 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
72% NTSC colour gamut, Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge
53.96 cm x 18.61 cm x 40.5 cm - with stand
3.46 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
13.2 W
13.2 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.96 cm - depth: 18.61 cm - height: 40.5 cm - weight: 3.46 kg , Without stand - width: 53.96 cm - depth: 4.76 cm - height: 32.5 cm - weight: 3.14 kg
Shipping Width
58.8 cm
Shipping Depth
12.3 cm
Shipping Height
37.3 cm
Shipping Weight
4.7 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
G28S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £15.53
G28S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £30.10
G28S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
G28S HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £6.01
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Brand: HP
