See more of your work onscreen with less window toggling on the HP P24h G4 FHD Height Adjust Monitor. It has business-class presentation features, adjustable comfort, stereo audio, and advanced connectivity to complement today's workspaces.
Get comfortable
Find your best view with adjustable tilt settings, 100 mm of height adjustment, and 90° pivot rotation. -
Create an efficient workspace
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. -
Adjust your view
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view. -
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern. -
Responsibly made
Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT 2019 registered, and low halogen display.
- HP P24h G4 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Energy Consumption per Year
- 20.8 kWh
- Power Consumption (On mode)
- 15 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.82 cm x 21.16 cm x 46.43 cm
- 4.61 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CEL, EAC, ISC, low halogen, ICE
- Display Type
- Energy Class
- Class E
- 20.8 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, Mercury free, Factory Calibration, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut
- Black
- 53.82 cm x 21.16 cm x 46.43 cm - with stand
- 4.61 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort (HDCP) , HDMI (HDCP) , VGA , Audio line-in
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x audio cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15 W
- Power Consumption SDR (On mode)
- 15 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 53.82 cm - depth: 21.16 cm - height: 46.43 cm - weight: 4.61 kg , Without stand - width: 53.82 cm - depth: 4.59 cm - height: 32.56 cm - weight: 2.53 kg
- Shipping Width
- 59.8 cm
- Shipping Depth
- 16.5 cm
- Shipping Height
- 41.5 cm
- Shipping Weight
- 6.14 kg
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
