HP P24 G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: G28WWS00 Mfr#: 1A7E5AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15), DisplayPort
£129.72 ex VAT
£155.66 inc VAT
See more of your work onscreen with less window toggling on the HP P24 G4 monitor. It has business-class presentation features, and advanced connectivity to complement today's workspaces.
  • Crisp images for all your content
    Easily navigate documents and spreadsheets and work in multiple applications side by side on the 23.8" (60.45 cm) diagonal Full HD IPS screen with vibrant 1920 x 1080 resolution.
  • A beauty at any price
    Set a new style standard with a sleek design that has a 3-sided micro-edge bezel for practically unlimited sightlines and virtually seamless multi-display setups. See the screen clearly from almost anywhere in the room with 178° viewing angles.
  • Versatile connectivity
    Quickly connect to your devices and additional displays through the HDMI and DisplayPort connectors. Get legacy device compatibility from the VGA connector.
HP P24 G4 - P-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Energy Consumption per Year
20.8 kWh
Power Consumption (On mode)
15 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.82 cm x 21.16 cm x 46.43 cm
4.61 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, KC, CEL, EAC, ISC, DisplayPort 1.2, Australian-New Zealand MEPS, Vietnam MEPS
Display Type
Energy Class
Class E
20.8 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth, 72% NTSC colour gamut
53.82 cm x 21.16 cm x 46.43 cm - with stand
4.61 kg
DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
15 W
15 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 53.82 cm - depth: 21.16 cm - height: 46.43 cm - weight: 4.61 kg , Without stand - width: 53.82 cm - depth: 4.59 cm - height: 32.56 cm - weight: 2.53 kg
Shipping Width
59.8 cm
Shipping Depth
16.5 cm
Shipping Height
41.5 cm
Shipping Weight
6.14 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
5 °C
35 °C
20 - 80% (non-condensing)
G28W HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
G28W HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
G28W HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
G28W HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.83
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: HP
