See more of your work onscreen with less window toggling on the HP P24 G4 monitor. It has business-class presentation features, and advanced connectivity to complement today's workspaces.
Crisp images for all your content
Easily navigate documents and spreadsheets and work in multiple applications side by side on the 23.8" (60.45 cm) diagonal Full HD IPS screen with vibrant 1920 x 1080 resolution. -
A beauty at any price
Set a new style standard with a sleek design that has a 3-sided micro-edge bezel for practically unlimited sightlines and virtually seamless multi-display setups. See the screen clearly from almost anywhere in the room with 178° viewing angles. -
Versatile connectivity
Quickly connect to your devices and additional displays through the HDMI and DisplayPort connectors. Get legacy device compatibility from the VGA connector.
- HP P24 G4 - P-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Energy Consumption per Year
- 20.8 kWh
- Power Consumption (On mode)
- 15 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.82 cm x 21.16 cm x 46.43 cm
- 4.61 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, KC, CEL, EAC, ISC, DisplayPort 1.2, Australian-New Zealand MEPS, Vietnam MEPS
- Display Type
- Energy Class
- Class E
- 20.8 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth, 72% NTSC colour gamut
- Black
- 53.82 cm x 21.16 cm x 46.43 cm - with stand
- 4.61 kg
- DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15 W
- Power Consumption SDR (On mode)
- 15 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 53.82 cm - depth: 21.16 cm - height: 46.43 cm - weight: 4.61 kg , Without stand - width: 53.82 cm - depth: 4.59 cm - height: 32.56 cm - weight: 2.53 kg
- Shipping Width
- 59.8 cm
- Shipping Depth
- 16.5 cm
- Shipping Height
- 41.5 cm
- Shipping Weight
- 6.14 kg
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.83 |
