Tackle your daily task list with the budget-friendly HP P22v G4 Monitor that adjusts to your comfort needs and delivers Full HD picture quality.
Crisp image clarity for all your content
Get lifelike color and sharp details for everything you do on a 21.5" diagonal Full HD screen. -
Modern connectivity
Conveniently and quickly connect to your devices and additional monitors through the HDMI and VGA ports, no dongles required. -
Make conscientious buying choices
Choose a monitor that's TCO and ENERGY STAR certified to help meet your environmental buying requirements.
- HP P22v G4 - P-Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class D
- Energy Consumption per Year
- 19 kWh
- Power Consumption (On mode)
- 13 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.5 cm x 18.895 cm x 38.126 cm
- 2.85 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CECP, CEL, ISC, SEPA, BIS, ICE, Australian-New Zealand MEPS, Vietnam MEPS
- 3-year warranty
- Display Type
- Energy Class
- Class D
- 19 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Low Blue Light Mode, Mercury free, arsenic-free glass, 72% NTSC colour gamut
- Black
- 50.5 cm x 18.895 cm x 38.126 cm - with stand
- 2.85 kg
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.5 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13 W
- Power Consumption SDR (On mode)
- 13 kWh/1000h
- Power Consumption (Typical)
- 18.5 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 50.5 cm - depth: 18.895 cm - height: 38.126 cm - weight: 2.85 kg , Without stand - width: 50.5 cm - depth: 4.2 cm - height: 31.026 cm - weight: 2.48 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 38.7 cm
- Shipping Weight
- 3.79 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years - on-site
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £15.53 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £30.10 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £15.53 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £6.01 |
