Put your content front and center on the HP P22 G4 FHD Monitor. The stylish, sleek design delivers essential presentation features, visual comfort, and advanced connectivity at a remarkable price point.
Create an efficient workspace
Attach your HP PC or select HP Thin Client directly behind the display. -
Adjust your view
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. -
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern. -
Responsibly made
Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT 2019 registered, and low halogen display. -
Complete the picture
Customize a total solution with options designed for your display, like the HP S101 Speaker Bar. -
We have your back
We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack.
- HP P22 G4 - P-Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class E
- Energy Consumption per Year
- 19.3 kWh
- Power Consumption (On mode)
- 14 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 49.73 cm x 21.16 cm x 45.49 cm
- 4.14 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, KC, CEL, EAC, ISC, DisplayPort 1.2, Australian-New Zealand MEPS, Vietnam MEPS
- Display Type
- Energy Class
- Class E
- 19.3 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24795 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth
- Black
- 49.73 cm x 21.16 cm x 45.49 cm - with stand
- 4.14 kg
- DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14 W
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 49.73 cm - depth: 21.16 cm - height: 45.49 cm - weight: 4.14 kg , Without stand - width: 49.73 cm - depth: 4.59 cm - height: 30.11 cm - weight: 2.06 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 18.9 cm
- Shipping Height
- 38.5 cm
- Shipping Weight
- 5.65 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.83 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GSNG 048487 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048488 Condition: item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048489 Condition: item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048490 Condition: item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048491 Condition: item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048492 Condition: item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048493 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048494 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048495 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048496 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048497 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048498 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048499 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048500 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048501 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048502 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048503 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048504 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048506 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048507 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048508 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048509 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048510 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048511 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048512 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048513 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048514 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048515 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048516 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048517 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048518 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048519 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048520 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048521 Condition: Item has been opened. Is in excellent condition |
£87.13 | |||||
Ref:
GSNG 048522 Condition: Item has been opened. Is in excellent condition |
£87.13 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
