Put your content front and center on the HP P22 G4 FHD monitor. The stylish, sleek design delivers essential presentation features, visual comfort, and advanced connectivity.
Create an efficient workspace
Attach your HP PC or select HP Thin Client directly behind the display. -
Adjust your view
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. -
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern. -
Responsibly made
Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT 2019 registered, and low halogen display. -
Complete the picture
Customize a total solution with options designed for your display, like the HP S101 Speaker Bar. -
We have your back
We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack.
- HP P22 G4 - P-Series - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class E
- Energy Consumption per Year
- 19.3 kWh
- Power Consumption (On mode)
- 14 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 230V (50/60 Hz)
- Black
- 49.73 cm x 21.16 cm x 45.49 cm
- 4.14 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, KC, CEL, EAC, ISC, DisplayPort 1.2, Australian-New Zealand MEPS, Vietnam MEPS
- 3-year warranty
- Display Type
- Energy Class
- Class E
- 19.3 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth
- Black
- 49.73 cm x 21.16 cm x 45.49 cm - with stand
- 4.14 kg
- DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14 W
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 49.73 cm - depth: 21.16 cm - height: 45.49 cm - weight: 4.14 kg , Without stand - width: 49.73 cm - depth: 4.59 cm - height: 30.11 cm - weight: 2.06 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 18.9 cm
- Shipping Height
- 38.5 cm
- Shipping Weight
- 5.65 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
