HP P22 G4 21.5" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: G28VWS00 Mfr#: 1A7E4AT#ABU
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), HDMI, DisplayPort
£122.22 ex VAT
£146.66 inc VAT
Put your content front and center on the HP P22 G4 FHD monitor. The stylish, sleek design delivers essential presentation features, visual comfort, and advanced connectivity.
  • Create an efficient workspace
    Attach your HP PC or select HP Thin Client directly behind the display.
  • Adjust your view
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT 2019 registered, and low halogen display.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S101 Speaker Bar.
  • We have your back
    We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack.
HP P22 G4 - P-Series - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class E
Energy Consumption per Year
19.3 kWh
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 230V (50/60 Hz)
49.73 cm x 21.16 cm x 45.49 cm
4.14 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, KC, CEL, EAC, ISC, DisplayPort 1.2, Australian-New Zealand MEPS, Vietnam MEPS
3-year warranty
Display Type
Energy Class
Class E
19.3 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, Flicker Free technology, Color Calibrated, 3-sided micro-edge, 6-bit + A-FRC Color Depth
49.73 cm x 21.16 cm x 45.49 cm - with stand
4.14 kg
DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HDCP Compliant, arsenic free, mercury free
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
AC 230V (50/60 Hz)
14 W
14 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 49.73 cm - depth: 21.16 cm - height: 45.49 cm - weight: 4.14 kg , Without stand - width: 49.73 cm - depth: 4.59 cm - height: 30.11 cm - weight: 2.06 kg
Shipping Width
56.7 cm
Shipping Depth
18.9 cm
Shipping Height
38.5 cm
Shipping Weight
5.65 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
G28V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
G28V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
G28V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
G28V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.83
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: HP
