Get essential presentation features and device connectivity with the stylishly redesigned and surprisingly cost-conscious HP P204 19.5-inch Monitor.
Crisp image clarity for all your content
Easily navigate your documents and spreadsheets on this sleek display that complements your modern workspace and has a 19.5-inch diagonal screen with 1600 x 900 resolution. -
Essential connectivity
Quickly connect to your devices and additional displays through the HDMI and DisplayPort connectors. Get legacy device compatibility from the VGA connector. -
Create an efficient workspace
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
- HP P204 - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Energy Class
- Class A+
- Energy Consumption per Year
- 18.9 kWh
- Power Consumption (On mode)
- 13 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- HD+ 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Black
- 46.26 cm x 19 cm x 35.36 cm
- 2.84 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, ISO 9001, GS, CB, CCC, PSB, FCC, KCC, WEEE, ICES, S Mark, cTUVus, MEPS, E-Standby, KC, ERP, CEL, EAC, ISC, RCM, MSIP, BIS, CoC, low halogen
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 18.9 kWh
- 13 W
- Diagonal Size
- 19.5"
- Viewable Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94.1
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 70 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Bezel Type
- Raised
- 72% colour gamut, Frame Rate Control (FRC), Flicker Free technology, Mercury free, arsenic-free glass
- Black
- 46.26 cm x 19 cm x 35.36 cm - with stand
- 2.84 kg
- VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m
- Backlight Life
- 40,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 15 Watt
- Power Consumption Stand by
- 0.3 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 46.26 cm - depth: 4.87 cm - height: 27.87 cm - weight: 2.26 kg , With stand - width: 46.26 cm - depth: 19 cm - height: 35.36 cm - weight: 2.84 kg
- Shipping Width
- 54.3 cm
- Shipping Depth
- 13.6 cm
- Shipping Height
- 34.9 cm
- Shipping Weight
- 4.05 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
