HP P19b G4 19" 1366x768 5ms VGA HDMI LED Monitor
Quicklinx: G28QWS00 Mfr#: 9TY83AT#ABU
£115.00 ex VAT
£138.00 inc VAT
Tackle your daily task list and save space on your desk with the compact, budget-friendly HP P19b G4 Monitor that adjusts to your comfort needs and delivers HD picture quality.
  • We have your back
    Rest assured that your IT investment has a long lifecycle and is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack service.
HP P19b G4 - P-Series - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Energy Class
Class C
Energy Consumption per Year
12 kWh
Power Consumption (On mode)
8.3 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
WXGA 1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 8000000:1 (dynamic)
Response Time
5 ms
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, Haze 25%
Voltage
Jack black
44.14 cm x 15.7 cm x 34.58 cm
2.45 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Silver
Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, KCC, WEEE, cTUVus, E-Standby, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, Mexico Energy label, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, TGM, Mexico LASE form
3-year warranty
Display Type
Energy Class
Class C
12 kWh
Diagonal Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Low Blue Light Mode, Flicker Free technology, Mercury free, Color Calibrated, 72% NTSC colour gamut
Jack black
44.14 cm x 15.7 cm x 34.58 cm - with stand
2.45 kg
HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable - 1.5 m
Mounting Kit
Included
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
8.3 W
8.3 kWh/1000h
Power Consumption (Typical)
10 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
Without stand - width: 44.14 cm - depth: 5.07 cm - height: 27.78 cm - weight: 2.2 kg , With stand - width: 44.14 cm - depth: 15.7 cm - height: 34.58 cm - weight: 2.45 kg
Shipping Weight
3.27 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
