HP P174 17" 1280x1024 5ms VGA LED Monitor
Quicklinx: FBQ7WS00 Mfr#: 5RD64AT#ABU
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Hurry, only 2 left in stock!
£101.37 ex VAT
£121.64 inc VAT
Meet your business needs and your budget with solid front-of-screen visuals and easy PC connectivity of the stylish, reliable, and affordable HP P174 17-inch Monitor.
  • Crisp, clear views
    Navigate your everyday content and specific line of business programs on a sleek display that complements your modern workspace and has a standard 17-inch diagonal 1280 x 1024 resolution screen.
  • Simple connectivity
    Connect to your current and legacy devices through the VGA port.
  • Create an efficient workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
HP P174 - LED monitor - 17"
LED-backlit LCD monitor - 17"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
37.48 cm x 19 cm x 38.59 cm
2.6 kg
English / United Kingdom
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI, BSMI, CB, CCC, FCC, KCC, Green Mark, ICES, S Mark, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, ISC, RCM, SEPA, BIS, CE/EMC, TUV LBL, IEC 62368
3-year warranty
Display Type
Diagonal Size
17"
Viewable Size
17"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Pixel Per Inch
96.2
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
On-screen Digital Controls, Mercury free, arsenic-free glass
37.48 cm x 19 cm x 38.59 cm - with stand
2.6 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+25
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable - 1.8 m
Pricing Type
Promo
Security Slot Type
Kensington security slot
12 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 37.48 cm - depth: 19 cm - height: 38.59 cm - weight: 2.6 kg , Without stand - width: 37.48 cm - depth: 5.07 cm - height: 31.23 cm - weight: 2.02 kg
Shipping Width
46.1 cm
Shipping Depth
13.6 cm
Shipping Height
38 cm
Shipping Weight
3.6 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HP P174 17 Bundle deal on HP P174 17" 1280x1024 5ms VGA LED Monitor
£200.54
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Brand: HP
Price Range Ex VAT: 100 - 150
