Work confidently and stylishly on HP's sleek and light full performance mobile workstation.
Take mobile to the next level
Featuring 4th Generation Intel Core i7 quad-core processors, Windows 7, HP Z Turbo Drive PCIe storage and, professional NVIDIA Quadro K1100M graphics, the HP OMEN Pro packs all the performance you'd expect from an HP Mobile Workstation. -
Then take it on the go
Sleek design and impressive power define the HP Omen Pro Mobile Workstation. At just .61 in/15.5 mm thin, this system is meant for going mobile. A backlit keyboard and FHD Touch Panel help keep you ready for different computing environments. -
And work confidently on your favorite software
With full ISV certification for your favorite Product Development, AEC, and Media & Entertainment applications, the HP OMEN Pro provides complete compatibility between hardware and software that is stable and designed to perform.
- OMEN by HP Laptop Pro - 15.6" - Intel Core i7 - 4870HQ - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit - English
- Processor
- Intel Core i7 (4th Gen) - 4870HQ / 2.5 GHz, up to 3.7 GHz / 6 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD - HP Z Turbo Drive
- Display
- 15.6" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro K1100M
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 4-cell - up to 5 hours
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 38.29 cm x 24.75 cm x 1.55 cm
- 2.12 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (4th Gen) 4870HQ / 2.5 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM87 Express
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
Storage
- Main Storage
- 256 GB SSD PCIe - HP Z Turbo Drive
Display
- 15.6" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- Shader Model 5.0
- Camera
- Yes - Full HD
- Camera Features
- HP TrueVision FHD
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3227
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Touchpad with gesture support, HP Control Zone
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 4-cell lithium polymer
- Capacity
- 58 Wh
- Run Time
- Up to 5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 120 Watt, 19.5 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , 4 x USB 3.0 , Mini DisplayPort
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- HP Performance Advisor
- Security
- Microphone with echo and noise-cancellation, 1 USB 3.0 charging port
- Included Accessories
- Power adapter
- UL, VCCI, CCC, FCC, KCC, A-Tick, ICES
- Localization
- 2.12 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
