HP Officejet PRO AIO Wireless 6970 Inket 30 ppm
Quicklinx: D9F7WS00 Mfr#: T0F33A#BHC
43 in stock
£94.42 ex VAT
£113.30 inc VAT
Supercharge the office with affordable color and fast two-sided performance. Save paper with automatic two-sided printing, and handle more tasks without slowing down. Get a variety of mobile printing options and seamless mobile setup.
  • Save up to 70% on ink with HP Instant Ink
    Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty.
  • Remarkable value for professional, in-office colour
    Manage your budget with professional-quality colour at up to 50% less cost per page than lasers.Print up to 5x as many black text pages with optional Original HP high-yield ink cartridges.Produce professional-quality colour and black text that's perfect for printing reports, charts, and more.Rely on Original HP pigment inks for durable prints that resist water and last for decades.
  • Easy mobile printing, seamless mobile setup
    Easily print from a variety of smartphones and tablets.Connect a smartphone or tablet directly to the printer and easily print without a network.Print wirelessly, and share this all-in-one with other wireless-enabled devices.Easily manage printing tasks and scan on the go, with the HP All-in-One Printer Remote mobile app.
  • Handle more tasks and effortlessly scan
    Set the pace for success with rapid print, scan, and copy speeds.Save paper and conserve resources – consume up to 50% less paper with automatic two-sided printing.Make scanning effortless and accurate. Never turn a page again when you need to scan two-sided documents.Quickly copy, scan, and fax multipage documents with the 35-page two-sided automatic document feeder.
HP Officejet Pro 6970 All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
200 - 800 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 30 ppm (mono) / up to 26 ppm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
88.9 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, recycled paper, photo paper, thick paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to folder
AC 120/230 V (50/60Hz)
46.37 cm x 39 cm x 22.867 cm
8.1 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
200 - 800 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
1 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
20 station(s)
Broadcast Transmission
20 stations
Delayed Transmission
Yes (black only)
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), Double Sided Faxing
Document & Media Handling
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
88.9 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 88.9 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Borderless Photo Sizes
225 sheets
60 sheets
Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 35 sheets - Legal (216 x 356 mm) , Output tray - 60 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W draft , Printing: up to 26 ppm (A4) - colour draft , Printing: up to 20 ppm (A4) - B/W normal , Printing: up to 11 ppm (A4) - colour normal , Scanning: up to 8 ppm (A4) - B/W , Scanning: up to 3.5 ppm (A4) - colour , Copying: up to 30 ppm (A4) - B/W draft , Copying: up to 24 ppm (A4) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Printing: up to 3.5 ppm (A4) - B/W best , Scanning: up to 4 ppm (A4) - B/W duplex , Scanning: up to 1.5 ppm (A4) - colour duplex , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
SSL, Apple Bonjour, LEAP, TLS, ARP, Wi-Fi Direct, EAP-TLS, PEAP
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012, MS Windows Server 2003 SP1, MS Windows Server 2003 SP2, Apple Mac OS X 10.9, MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP1 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
Dropbox, Google Drive, Microsoft DotNet
27 Watt
Power Consumption Standby
5.5 Watt
Power Consumption Sleep
1.21 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 265 pages - HP 903 , 1 x Cartridge (cyan) - HP 903 , 1 x Cartridge (magenta) - HP 903 , 1 x Cartridge (yellow) - HP 903
FCC Class B certified, BSMI, RSS-210, CS-03, FCC CFR47 Part 68, R&TTE, FCC CFR47 Part 15, EN 60950-1, KCC, FCC CFR47 Part 15 C, KC, VCCI V-2, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 300 328 V1.7.1, NCC, iDA, ICES-003 issue 5 Class B, IEC60950-1:2005, Second edition + A1:2009, RCM, Directive 1999/519/EC, EMC 2004/108/EC, LVD 2006/95/EC, EN 301 489, CSA 22.2 No. 60950-1, EN 301 489-17 V2.1.1, EN55022:2010 Class B, EN 55024:2010, ETSI ES 203 021-2 V2.1.2 (2006-01), ETSI ES 203 021-3 V2.1.2 (2006-01), CISPR 22:2008, EN 62311:2008, IEC 62311:2007
ENERGY STAR Certified
Limited warranty - 3 years with product registration (within 60 days of purchase)
46.37 cm
39 cm
22.867 cm
8.1 kg
Shipping Width
50.8 cm
Shipping Depth
28.2 cm
Shipping Height
46.4 cm
Shipping Weight
10 kg
Sound Emission
61 dBA (operating)
5 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: 50 - 100
