The professional colour inkjet printer for distributed offices and hybrid workforce from the World's #1 Printer Company, paired with our best technology to help manage it all. This streamlines work into any network. Scan/copy/fax included.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Deploy, integrate and customize with ease
Easily deploy, integrate, and set up your fleet of printers across multiple locations. Customize and manage your fleet however you need with easy, remote management and enhanced feature control. -
Empower your business with a productivity powerhouse
Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray. Avoid waiting by the printer with an automatic document feeder enabling double-sided scanning. Speed up your printing with a fast inkjet printer. -
Advanced technology to help manage it all
Stay connected with a reliable dual-band, self-healing Wi-Fi that automatically reconnects.
- HP Officejet Pro 9120b All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 19 ppm (mono) / up to 14 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 20 ppm (mono) / up to 16 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
- Power
- AC 120/230 V (50/60Hz)
- 43.93 cm x 34.25 cm x 27.8 cm
- 9.29 kg
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- 1500 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 5, PCL 6, PDF
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
Fax Machine Features
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Min Original Size
- 76.2 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), A4 (210 x 297 mm)
- Borderless Photo Sizes
- 250 sheets
- 250 sheets
- 60 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Printing: up to 32 ppm (A4) - B/W draft , Printing: up to 32 ppm (A4) - colour draft , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 21 ppm (A4) - colour draft , Scanning: up to 8 ipm (A4) - B/W , Scanning: up to 8 ipm (A4) - colour , Scanning: up to 4 ipm (A4) - B/W duplex , Scanning: up to 4 ipm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 4 ppm (A4) - colour best , Copying: up to 19 ppm - B/W (ISO) , Copying: up to 28 ppm (A4) - B/W , Copying: up to 14 ppm - colour (ISO) , Copying: up to 21 ppm (A4) - colour
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- SSL, TLS, WPA2, 802.1x, WPA2-Enterprise
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
- Software Included
- Software HP Printer
- Voltage Required
- Power Consumption Standby
- 5.06 Watt
- Power Consumption Sleep
- 1.22 Watt
- First Copy Out Time B/W
- 8 sec
- First Copy Out Time Colour
- 10 sec
- Consumables Included
- 1 x ink cartridge (black) - HP 937 , 1 x ink cartridge (cyan) - HP 937 , 1 x ink cartridge (magenta) - HP 937 , 1 x ink cartridge (yellow) - HP 937
- BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Limited hardware warranty - 1 year , Technical support - 1 year
- 43.93 cm
- 34.25 cm
- 27.8 cm
- 9.29 kg
- Shipping Width
- 48.7 cm
- Shipping Depth
- 32.5 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 11.35 kg
- Sound Emission
- 63 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
Ink (10)
HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge | In Stock | £82.19 |
HP 937e EvoMore - yellow - original - ink cartridge | In Stock | £37.18 |
HP 937e EvoMore - magenta - original - ink cartridge | In Stock | £37.08 |
HP 937e EvoMore - black - original - ink cartridge | In Stock | £56.52 |
HP 937e EvoMore - magenta - original - ink cartridge | In Stock | £37.31 |
HP 937e EvoMore - cyan - original - ink cartridge | In Stock | £37.31 |
HP 937e EvoMore - black - original - ink cartridge | In Stock | £58.63 |
HP 937e EvoMore - yellow - original - ink cartridge | In Stock | £38.70 |
HP 937e EvoMore - magenta - original - ink cartridge | In Stock | £38.70 |
HP 937e EvoMore - cyan - original - ink cartridge | In Stock | £38.70 |
