Count on fast print speeds up to to 24 ppm, single-pass two-sided copy/scan, automatic two-sided printing, and an extra-large 500 sheet paper tray. Includes HP+ benefits. 6 free months of Instant Ink and an extended up to 3 year HP warranty.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer. This printer uses dynamic security, which may be updated periodically by firmware updates. The printer is intended to be used solely with cartridges using an original HP chip. Cartridges using a non-HP chip may not function or may cease to function.
Customisable shortcuts on your phone or printer
Eliminate steps in repetitive tasks with Shortcuts in HP app. -
Create editable, searchable documents
With Shortcuts in HP app, you can create editable, searchable documents by scanning from your phone or printer. -
Two-sided. Hands-free. Auto-fed
Work fast and hands-free with the 35 page auto-feeder. Quickly scan both sides of a page at once. -
Print at high volumes with dual-tray capacity
Take on high-volume jobs with confidence, using two 250 sheet paper trays that fit a full ream of paper. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
- HP Officejet Pro 9025e All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 2000 pages
- Max Copying Speed
- Up to 23 ppm (mono) / up to 17 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 24 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
- Power
- AC 120/230 V (50/60Hz)
- 43.7 cm x 39.6 cm x 31.83 cm
- 11.66 kg
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 2000 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 6272 nozzles
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Ink Palette Supported (Colours)
- Pigment cyan, pigment magenta, pigment yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Min Original Size
- 76.2 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- 250 sheets
- 250 sheets
- 100 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 24 ppm (A4) - B/W (ISO) , Printing: up to 20 ppm (A4) - colour (ISO) , Printing: up to 39 ppm (A4) - B/W draft , Printing: up to 39 ppm (A4) - colour draft , Copying: up to 39 ppm (A4) - B/W draft , Copying: up to 39 ppm (A4) - colour draft , Scanning: up to 15 ppm (A4) - B/W , Scanning: up to 8 ipm (A4) - colour , Scanning: up to 15 ppm (A4) - B/W duplex , Scanning: up to 6 ppm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 4 ppm (A4) - colour best
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- SSL, TLS, WPA2, 802.1x, WPA2-Enterprise
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
- Software Included
- Software HP Printer
- Voltage Required
- 30 Watt
- Power Consumption Standby
- 5.8 Watt
- Power Consumption Sleep
- 1.22 Watt
- First Copy Out Time B/W
- 7 sec
- First Copy Out Time Colour
- 9 sec
- Consumables Included
- 1 x ink cartridge (black) - HP 963 , 1 x ink cartridge (cyan) - HP 963 , 1 x ink cartridge (magenta) - HP 963 , 1 x ink cartridge (yellow) - HP 963
- FCC CFR47 Part 15 B, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 301 489-1, EN 61000-3-2:2014, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Limited warranty - parts - 1 year , Technical support - web support - 1 year
- 43.7 cm
- 39.6 cm
- 31.83 cm
- 11.66 kg
- Shipping Width
- 49.6 cm
- Shipping Depth
- 37.7 cm
- Shipping Height
- 48.9 cm
- Shipping Weight
- 14.2 kg
- Sound Emission
- 64 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
Ink (9)
HP 963 Black Original Ink Cartridge | In Stock | £23.81 |
HP 963 Cyan Original Ink Cartridge | In Stock | £17.43 |
HP 963 Magenta Original Ink Cartridge | In Stock | £17.43 |
HP 963 Yellow Original Ink Cartridge | In Stock | £17.43 |
HP 963XL High Yield Black Original Ink Cartridge | In Stock | £37.12 |
HP 963XL High Yield Cyan Original Ink Cartridge | In Stock | £27.69 |
HP 963XL High Yield Magenta Original Ink Cartridge | In Stock | £27.69 |
HP 963XL High Yield Yellow Original Ink Cartridge | In Stock | £27.69 |
HP HP 963 4-Pack Original Ink Cartridge | In Stock | £75.33 |
Other bundles (1)
HP Care Pack Next Business Day Hardware Exchange - Extended | In Stock | £60.66 |
